Question about RotateLabel
I am using TChart 2015.15.150420 32 bit and I am using Canvas3D.RotateLabel to draw a rotated text. The last parameter of the RotateLabel procedure is AllowHTML which I set to true. What HTML should I use to present a subscript character?
Re: Question about RotateLabel
<SUB>SubScript Text Here</SUB>
Hello Yeray,
I tried that but unfortunately it does not work, my actual code is:
Am I missing something?
procedure TMainForm.Chart11AfterDraw(Sender: TObject);
TChart(Sender).Canvas.RotateLabel(X, Y, '<SUB>SubScript Text Here</SUB>', 45 , true);
Hello johnnix,
It works for me compared with non-subscript text, for example:
var X, Y: Integer;
TChart(Sender).Canvas.Font.Size:=15;
X:=100;
Y:=X;
TChart(Sender).Canvas.RotateLabel(X, Y, 'Normal Text <SUB>SubScript Text Here</SUB>', 45 , true);
Hello Narcis,
Could it be my version? I just tried a plot Title in HTML and that does not work also (double clicked a plot -> Titles -> Options -> Format HTML)
I've just checked it works in v2015.15 for me here: The position of the Subscript text isn't correct with oblique angles, but the text and the font size look correct.
Note I've added this to output the build version string on the chart title:
uses TeeConst;
Chart1.Title.Text.Text:=TeeMsg_Version;
... does not work for me What could be the issue?
- Screenshot 2015-10-15 21.png (12.36 KiB) Viewed 23409 times
What IDE are you using?
Delphi XE7 Version 21.0.17707.5020
Looking again at your screenshot I've seen what is making the difference here: RotateLabel method doesn't support HTML5 tags in GDI Canvas.
http://bugs.teechart.net/show_bug.cgi?id=1343
In the meanwhile you can use GDIPlus instead of GDI.
Understood
Reviewing if it's worth implementing the support for the HTML in RotateLabel, doesn't GDIPlus satisfy your needs?
