TeeChart7.02Builder6 Installer - Wrong recognition of BCB6
re
Post by re » Tue Dec 28, 2004 8:21 am
the new Installer does not recognize the correct BCB version.
Installer: "Borland Builder 6 Standard version found"
Your Borland Builder version level is "Standard".
Borland Builder Standard version does not include QuickReport, Database support and Decision Cube packages.
For this reason, the TeeChart for QuickReport, the database Chart and DecisionGraph components will not be installed
My system:
- C++Builder 6 Enterprise German (Update Pack 4),
- Win2k SP4
- TeeChart Pro 7.0 VCL/CLX License (without source code)
Previous ones Installer of TeeChart (7 and 7.01) recognized the correct BCB version. The installations did not run however for the well-known reasons successfully.
I would like to finally use TeeChart Pro in my projects. So far I wasted very much time with the integration of TeeChart Pro in BCB6 after the broken off installations.
When is a correct version finally available of Installer?
Ralf
Marjan
Post by Marjan » Tue Dec 28, 2004 10:06 am
Hi, Ralf.
The installer only looks in the registry if your BCB version is correct. Perhaps the problem is your BCB registry entries are not what installer expects. Please check if the following registry key exists and what is it's value:
HKEY_CURRENT_USER\Software\Borland\C++Builder\6.0\Version
In case you're using Enterprise version and it was installed correctly the Version should contain only "CSS" string.
Marjan Slatinek,
re
Post by re » Tue Dec 28, 2004 2:11 pm
Hi Marjan,
the entries in Registry seem to be corrected?
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Borland\C++Builder\6.0]
"UseSharedFiles"="TRUE"
"Version"="CSS"
"App"="C:\\Programme\\Borland\\CBuilder6\\Bin\\bcb.exe"
"RootDir"="C:\\Programme\\Borland\\CBuilder6"
"Update #4"="TRUE"
Is there another possibility of convincing Installer of that the correct BCB version? Thank you.
Ralf
Marjan wrote: ...
Pep
Post by Pep » Tue Dec 28, 2004 11:19 pm
Hi Ralf,
I've just test it here (using Win2k SP4 and BCB6 Ent. and the latest v7.02 installer) and works fine, all the components has been installed correctly.
Maybe the problem is a corrupted installer. Have you tried to download it again from our web site ?
re
Post by re » Mon Jan 03, 2005 8:59 am
just still once Installer loaded:
TeeChart7.02Builder6..> 27-Dec-2004 08:40  23.0M
The result is unfortunately identical.
Can it be because of the language version (WinXP, BCB6)? I use in each case the German versions ...
Ralf
Pep
Post by Pep » Mon Jan 03, 2005 9:16 am
Hi Ralf,
this should not be problematic, have you tried to install it on another machine ?
David Berneda
Post by David Berneda » Mon Jan 03, 2005 7:20 pm
The installer looks for HKEY_LOCAL_MACHINE, not HKEY_CURRENT_USER
[HKEY_LOCAL_MACHINE\Software\Borland\C++Builder\6.0]
"Version"="CSS"
Do you have this ok at registry hkey_local_machine?
regards
david
"Version"="CSS"
re
Post by re » Tue Jan 04, 2005 8:29 am
Hi David,
seems correctly too:
[HKEY_LOCAL_MACHINE\SOFTWARE\Borland\C++Builder\6.0]
"LocalSharedRoot"="C:\\Programme\\Gemeinsame Dateien\\Borland Shared"
"Update #4"="TRUE"
"UseSharedFiles"="FALSE"
"Version"="CSS"
Regards, Ralf
David wrote:The installer looks for HKEY_LOCAL_MACHINE, not HKEY_CURRENT_USER
"Version"="CSS"
Joerg
Post by Joerg » Wed Jan 05, 2005 9:07 am
I've exactly the same problems:
My system:
- Win XP Pro German
- TeeChart Pro 7.0 VCL License
Previous ones Installer of TeeChart (7 and 7.01) recognized the correct BCB version, but there were some bugs with pie charts in 7.0 and teetree within 7.01.
L-O
Post by L-O » Thu Jan 06, 2005 10:05 am
I ahve also the same problem that the installer not recognize my version of BCB. I have C++ Builder 6 Pro (Update pack 4).
The registry is correct, it stands PRO for my version.
Lars-Olof
re
Post by re » Fri Jan 07, 2005 9:06 am
perhaps Steema finally a correct version makes available Installer ...
- Identification BCB
- Correct TeeChart integration in BCB
So far I have much time wasted with the integration of the previous version.
Regrads, Ralf
Joerg
Post by Joerg » Tue Jan 11, 2005 12:50 pm
there is a new teechart version for BCB, see thread 'Installing 7.02 under BCB 6 Professional - No Include files '.
this installation works, but...
