We are trying to install Teechart VII on a system with Teechart V installed and Report-Builder installed[don't know the version]. When we try install the components, they will not install saying there is another TEAbout installed. We had this issue a couple of years ago, but don't remember the solution.
Will I have the same issuer installing on a system with Tchart VI and repotrbuilder?
Jennifer
Teechart VII/Reportbuilder
Hi Jennifer,
This would seem that Delphi is still referencing old TeeChart packages. You should make sure to remove/backup TeeChart packages bundled with Delphi from the menu item Project>Options>Packages, reinstall TeeChart v7 and check the search paths are correct at Project>Options>Directories.
