TeeGrid - Delphi 11
laiyukwa
TeeGrid - Delphi 11
Post by laiyukwa » Wed Sep 15, 2021 4:31 am
Delphi 11 has just been released. Whether TeeGrid will be supported it ?
Re: TeeGrid - Delphi 11
Post by Yeray » Thu Sep 16, 2021 11:26 am
We are working on new installers for TeeGrid to support RAD 11.
Post by Marc » Thu Sep 16, 2021 1:41 pm
Greetings,
The new installer for RAD Studio 11 is now available for download.
See: https://www.steema.com/version_info/gridvcl/last for information.
Download available via the customer page: https://www.steema.com/login
laiyukwa
Post by laiyukwa » Fri Oct 29, 2021 7:10 am
I have installed the Teegrid 1.11 into Delphi 11 but the compiler is showing FMXTee.control not found.
Please help
laiyukwa
Post by laiyukwa » Fri Oct 29, 2021 9:16 am
The compiler is showing FMXTee.Control and FMXTee.Grid not found in building Linux 64 application. Under Windows Apps is no problem.
Post by Yeray » Fri Nov 05, 2021 7:55 am
I see TeeGridRecompile builds TeeGrid 1.11 for linux platform in RAD 11 without errors:
But the "Compiled\Delphi28.linux64\Lib" folder doesn't contain any "FMXTee.*" unit. We'll revise it.
In the meanwhile, I've checked adding the "Sources" and "Sources\FMX" folders to the "Library path" for "Linux 64-bit" platform works fine.
laiyukwa
Post by laiyukwa » Thu Nov 11, 2021 4:36 am
I have noted your reply but how to resolve it ?
On the other hand, I have tried to download the teegrid binary 1.11 from the official web site but the downloaded binary is only 2K file instead of 1392MB as stated in the web site.
Post by Yeray » Thu Nov 11, 2021 7:50 am
As I mentioned above, you could add the "Sources" and "Sources\FMX" folders to the "Library path" for "Linux 64-bit" platform. Have you tried it?
I've just downloaded TeeGrid-Binary-1.11.exe and it's 13,9MB. Could you please try it again?
Where have you seen it's 1392MB?
laiyukwa
Post by laiyukwa » Fri Nov 12, 2021 3:23 am
Sorry, the web site is showing 13,92MB but the downloaded binary is only 2kb even I use the browser of Firefox and Safari in Mac Computer as the same result of in windows platform. Such download file is only 2kb.
Post by Yeray » Fri Nov 12, 2021 9:16 am
The public link to TeeGrid Binary v1.11 is here:
https://www.steema.com/files/teegrid/in ... y-1.11.exe
laiyukwa
Post by laiyukwa » Sat Nov 13, 2021 4:11 am
Thank you for your help
laiyukwa
Post by laiyukwa » Thu Dec 16, 2021 4:22 am
I have just had the time to build Linux-64 bit according to your indication. However, this method cannot be worked. It is the same result "Compiled\Delphi28.linux64\lib" folder doesn't contain any "FMXTee.*" unit.
Please help again.
Post by Yeray » Wed Dec 22, 2021 8:48 am
Have you tried adding the "Sources" and "Sources\FMX" folders to the "Library path" for "Linux 64-bit" platform?
laiyukwa
Post by laiyukwa » Thu Dec 23, 2021 6:34 am
Have already adding to "Ordered list of Library paths" of Linux 64-bit platform. But no help.
Post by Yeray » Thu Dec 23, 2021 7:32 am
What error are you getting?
