Tooltip is slow
SenSeo
Tooltip is slow
Post by SenSeo » Mon Jun 27, 2016 1:43 pm
I have added the below CSS class and html code to achieve the chart responsive and working fine. But sometime tooltip is not showing or sometime it took more time to show tool tip. You can reproduce the same issue using sample code. Is there any way to fix the tooltip related issue? or How can we improve the tooltip speed?
One more thing what I observed is that this problem occurs when we assign height and width 100% to canvas using style sheet ( "<canvas id="canv" style="width:100%;height:100%;display:block;padding-left: 0;padding-right: 0; margin-left: 0; margin-right: 0;">")
If I don't set width and height to canvas the chart is displaying out of div(box), so how can we fix tooltip issue in this scenario?
<!DOCTYPE html>
<html>
<head>
    <title>TeeChart JavaScript Custom Axis Labels Example</title>
    <!--[if lt IE 9]>
        <script src="../../src/excanvas/excanvas_text.js"></script>
        <script src="../../src/excanvas/canvas.text.js"></script>
    <![endif]-->
    <style type="text/css">
        .col-md-12 {
            width: 100%;
        #canvas {
            width: 90%;
            height: 100%;
            /*background-color: pink;*/
            z-index: 100;
    </style>
    <script src="../../src/teechart.js" type="text/javascript"></script>
        var Chart1;
        function draw() {
            Chart1 = new Tee.Chart("canvas");
            var pointXY = new Tee.PointXY([355, 350, 346, 339, 332, 327, 320, 314, 305, 299, 291, 284, 278, 275, 269, 264, 262, 259, 257, 258,
              258, 259, 261, 263, 265, 266, 270, 271, 273, 276, 279, 268, 267, 268, 267, 266, 265, 262, 256, 252, 244, 238, 229, 220, 210, 200,
              191, 182, 172, 163, 154, 143, 135, 127, 120, 114, 108, 104, 101, 97, 96, 94, 95, 95, 96, 98, 101, 105, 110, 115, 122, 128, 137, 145,
              153, 163, 172, 183, 194, 206, 217, 228, 239, 250, 259, 270, 279, 289, 296, 304, 311, 316, 322, 325, 328, 331, 333, 332, 330, 329, 355,
              350, 346, 339, 332, 327, 320, 314, 305, 299, 291, 284, 278, 275, 269, 264, 262, 259, 257, 258, 258, 259, 261, 263, 265, 266, 270, 271, 273,
              276, 279, 268, 267, 268, 267, 266, 265, 262, 256, 252, 244, 238, 229, 220, 210, 200, 191, 182, 172, 163, 154, 143, 135, 127, 120, 114, 108,
              104, 101, 97, 96, 94, 95, 95, 96, 98, 101, 105, 110, 115, 122, 128, 137, 145, 153, 163, 172, 183, 194, 206, 217, 228, 239, 250, 259, 270,
              279, 289, 296, 304, 311, 316, 322, 325, 328, 331, 333, 332, 330, 329, 355, 350, 346, 339, 332, 327, 320, 314, 305, 299, 291, 284, 278, 275,
              269, 264, 262, 259, 257, 258, 258, 259, 261, 263, 265, 266, 270, 271, 273, 276, 279, 268, 267, 268, 267, 266, 265, 262, 256, 252, 244, 238,
              229, 220, 210, 200, 191, 182, 172, 163, 154, 143, 135, 127, 120, 114, 108, 104, 101, 97, 96, 94, 95, 95, 96, 98, 101, 105, 110, 115, 122, 128,
              137, 145, 153, 163, 172, 183, 194, 206, 217, 228, 239, 250, 259, 270, 279, 289, 296, 304, 311, 316, 322, 325, 328, 331, 333, 332, 330, 329, 355,
              350, 346, 339, 332, 327, 320, 314, 305, 299, 291, 284, 278, 275, 269, 264, 262, 259, 257, 258, 258, 259, 261, 263, 265, 266, 270, 271, 273, 276,
              279, 268, 267, 268, 267, 266, 265, 262, 256, 252, 244, 238, 229, 220, 210, 200, 191, 182, 172, 163, 154, 143, 135, 127, 120, 114, 108, 104, 101,
              97, 96, 94, 95, 95, 96, 98, 101, 105, 110, 115, 122, 128, 137, 145, 153, 163, 172, 183, 194, 206, 217, 228, 239, 250, 259, 270, 279, 289, 296, 304,
              311, 316, 322, 325, 328, 331, 333, 332, 330, 329, 355, 350, 346, 339, 332, 327, 320, 314, 305, 299, 291, 284, 278, 275, 269, 264, 262, 259, 257, 258,
              258, 259, 261, 263, 265, 266, 270, 271, 273, 276, 279, 268, 267, 268, 267, 266, 265, 262, 256, 252, 244, 238, 229, 220, 210, 200, 191, 182, 172, 163,
              154, 143, 135, 127, 120, 114, 108, 104, 101, 97, 96, 94, 95, 95, 96, 98, 101, 105, 110, 115, 122, 128, 137, 145, 153, 163, 172, 183, 194, 206, 217, 228,
              239, 250, 259, 270, 279, 289, 296, 304, 311, 316, 322, 325, 328, 331, 333, 332, 330, 329, 355, 350, 346, 339, 332, 327, 320, 314, 305, 299, 291, 284, 278,
              275, 269, 264, 262, 259, 257, 258, 258, 259, 261, 263, 265, 266, 270, 271, 273, 276, 279, 268, 267, 268, 267, 266, 265, 262, 256, 252, 244, 238, 229, 220,
              210, 200, 191, 182, 172, 163, 154, 143, 135, 127, 120, 114, 108, 104, 101, 97, 96, 94, 95, 95, 96, 98, 101, 105, 110, 115, 122, 128, 137, 145, 153, 163,
              172, 183, 194, 206, 217, 228, 239, 250, 259, 270, 279, 289, 296, 304, 311, 316, 322, 325, 328, 331, 333, 332, 330, 329, 355, 350, 346, 339, 332, 327, 320,
              314, 305, 299, 291, 284, 278, 275, 269, 264, 262, 259, 257, 258, 258, 259, 261, 263, 265, 266, 270, 271, 273, 276, 279, 268, 267, 268, 267, 266, 265, 262,
              256, 252, 244, 238, 229, 220, 210, 200, 191, 182, 172, 163, 154, 143, 135, 127, 120, 114, 108, 104, 101, 97, 96, 94, 95, 95, 96, 98, 101, 105, 110, 115,
              122, 128, 137, 145, 153, 163, 172, 183, 194, 206, 217, 228, 239, 250, 259, 270, 279, 289, 296, 304, 311, 316, 322, 325, 328, 331, 333, 332, 330, 329, 355,
              350, 346, 339, 332, 327, 320, 314, 305, 299, 291, 284, 278, 275, 269, 264, 262, 259, 257, 258, 258, 259, 261, 263, 265, 266, 270, 271, 273, 276, 279, 268,
              267, 268, 267, 266, 265, 262, 256, 252, 244, 238, 229, 220, 210, 200, 191, 182, 172, 163, 154, 143, 135, 127, 120, 114, 108, 104, 101, 97, 96, 94, 95, 95,
              96, 98, 101, 105, 110, 115, 122, 128, 137, 145, 153, 163, 172, 183, 194, 206, 217, 228, 239, 250, 259, 270, 279, 289, 296, 304, 311, 316, 322, 325, 328,
              331, 333, 332, 330, 329, 355, 350, 346, 339, 332, 327, 320, 314, 305, 299, 291, 284, 278, 275, 269, 264, 262, 259, 257, 258, 258, 259, 261, 263, 265, 266,
              270, 271, 273, 276, 279, 268, 267, 268, 267, 266, 265, 262, 256, 252, 244, 238, 229, 220, 210, 200, 191, 182, 172, 163, 154, 143, 135, 127, 120, 114, 108,
              104, 101, 97, 96, 94, 95, 95, 96, 98, 101, 105, 110, 115, 122, 128, 137, 145, 153, 163, 172, 183, 194, 206, 217, 228, 239, 250, 259, 270, 279, 289, 296,
              304, 311, 316, 322, 325, 328, 331, 333, 332, 330, 329, 355, 350, 346, 339, 332, 327, 320, 314, 305, 299, 291, 284, 278, 275, 269, 264, 262, 259, 257, 258,
              258, 259, 261, 263, 265, 266, 270, 271, 273, 276, 279, 268, 267, 268, 267, 266, 265, 262, 256, 252, 244, 238, 229, 220, 210, 200, 191, 182, 172, 163, 154,
              143, 135, 127, 120, 114, 108, 104, 101, 97, 96, 94, 95, 95, 96, 98, 101, 105, 110, 115, 122, 128, 137, 145, 153, 163, 172, 183, 194, 206, 217, 228, 239,
              250, 259, 270, 279, 289, 296, 304, 311, 316, 322, 325, 328, 331, 333, 332, 330, 329, 355, 350, 346, 339, 332, 327, 320, 314, 305, 299, 291, 284, 278, 275,
              269, 264, 262, 259, 257, 258, 258, 259, 261, 263, 265, 266, 270, 271, 273, 276, 279, 268, 267, 268, 267, 266, 265, 262, 256, 252, 244, 238, 229, 220, 210,
              200, 191, 182, 172, 163, 154, 143, 135, 127, 120, 114, 108, 104, 101, 97, 96, 94, 95, 95, 96, 98, 101, 105, 110, 115, 122, 128, 137, 145, 153, 163, 172,
              183, 194, 206, 217, 228, 239, 250, 259, 270, 279, 289, 296, 304, 311, 316, 322, 325, 328, 331, 333, 332, 330, 329, 355, 350, 346, 339, 332, 327, 320, 314,
              305, 299, 291, 284, 278, 275, 269, 264, 262, 259, 257, 258, 258, 259, 261, 263, 265, 266, 270, 271, 273, 276, 279, 268, 267, 268, 267, 266, 265, 262, 256,
              252, 244, 238, 229, 220, 210, 200, 191, 182, 172, 163, 154, 143, 135, 127, 120, 114, 108, 104, 101, 97, 96, 94, 95, 95, 96, 98, 101, 105, 110, 115, 122,
              128, 137, 145, 153, 163, 172, 183, 194, 206, 217, 228, 239, 250, 259, 270, 279, 289, 296, 304, 311, 316, 322, 325, 328, 331, 333, 332, 330, 329, 355, 350,
              346, 339, 332, 327, 320, 314, 305, 299, 291, 284, 278, 275, 269, 264, 262, 259, 257, 258, 258, 259, 261, 263, 265, 266, 270, 271, 273, 276, 279, 268, 267,
              268, 267, 266, 265, 262, 256, 252, 244, 238, 229, 220, 210, 200, 191, 182, 172, 163, 154, 143, 135, 127, 120, 114, 108, 104, 101, 97, 96, 94, 95, 95, 96,
              98, 101, 105, 110, 115, 122, 128, 137, 145, 153, 163, 172, 183, 194, 206, 217, 228, 239, 250, 259, 270, 279, 289, 296, 304, 311, 316, 322, 325, 328, 331,
              333, 332, 330, 329, 355, 350, 346, 339, 332, 327, 320, 314, 305, 299, 291, 284, 278, 275, 269, 264, 262, 259, 257, 258, 258, 259, 261, 263, 265, 266, 270,
              271, 273, 276, 279, 268, 267, 268, 267, 266, 265, 262, 256, 252, 244, 238, 229, 220, 210, 200, 191, 182, 172, 163, 154, 143, 135, 127, 120, 114, 108, 104,
              101, 97, 96, 94, 95, 95, 96, 98, 101, 105, 110, 115, 122, 128, 137, 145, 153, 163, 172, 183, 194, 206, 217, 228, 239, 250, 259, 270, 279, 289, 296, 304,
              311, 316, 322, 325, 328, 331, 333, 332, 330, 329, 355, 350, 346, 339, 332, 327, 320, 314, 305, 299, 291, 284, 278, 275, 269, 264, 262, 259, 257, 258, 258,
              259, 261, 263, 265, 266, 270, 271, 273, 276, 279, 268, 267, 268, 267, 266, 265, 262, 256, 252, 244, 238, 229, 220, 210, 200, 191, 182, 172, 163, 154, 143,
              135, 127, 120, 114, 108, 104, 101, 97, 96, 94, 95, 95, 96, 98, 101, 105, 110, 115, 122, 128, 137, 145, 153, 163, 172, 183, 194, 206, 217, 228, 239, 250,
              259, 270, 279, 289, 296, 304, 311, 316, 322, 325, 328, 331, 333, 332, 330, 329, 355, 350, 346, 339, 332, 327, 320, 314, 305, 299, 291, 284, 278, 275, 269,
              264, 262, 259, 257, 258, 258, 259, 261, 263, 265, 266, 270, 271, 273, 276, 279, 268, 267, 268, 267, 266, 265, 262, 256, 252, 244, 238, 229, 220, 210, 200,
              191, 182, 172, 163, 154, 143, 135, 127, 120, 114, 108, 104, 101, 97, 96, 94, 95, 95, 96, 98, 101, 105, 110, 115, 122, 128, 137, 145, 153, 163, 172, 183,
              194, 206, 217, 228, 239, 250, 259, 270, 279, 289, 296, 304, 311, 316, 322, 325, 328, 331, 333, 332, 330, 329, 355, 350, 346, 339, 332, 327, 320, 314, 305,
              299, 291, 284, 278, 275, 269, 264, 262, 259, 257, 258, 258, 259, 261, 263, 265, 266, 270, 271, 273, 276, 279, 268, 267, 268, 267, 266, 265, 262, 256, 252,
              244, 238, 229, 220, 210, 200, 191, 182, 172, 163, 154, 143, 135, 127, 120, 114, 108, 104, 101, 97, 96, 94, 95, 95, 96, 98, 101, 105, 110, 115, 122, 128,
              137, 145, 153, 163, 172, 183, 194, 206, 217, 228, 239, 250, 259, 270, 279, 289]);
            pointXY.format.stroke.size = 4;
            pointXY.pointer.style = "ellipse";
            pointXY.pointer.width = 5;
            pointXY.pointer.height = 5;
            Chart1.addSeries(pointXY);
            Chart1.axes.left.setMinMax(80, 360);
            Chart1.axes.left.format.stroke.fill = "green";
            Chart1.axes.left.title.text = "Left Axis";
            Chart1.axes.bottom.title.text = "Bottom Axis";
            Chart1.title.text = "Mouse-over Tooltips";
            Chart1.title.format.font.style = "18px Verdana";
            Chart1.series.items[0].format.stroke.fill = "darkorange";
            Chart1.series.items[0].pointer.visible = true;
            Chart1.panel.format.stroke.fill = "";
            Chart1.panel.format.shadow.visible = true;
            tip = new Tee.ToolTip(Chart1);
            tip.render = "dom";
            tip.domStyle = "padding-left:8px; padding-right:8px; padding-top:0px; padding-bottom:4px; margin-left:5px; margin-top:0px;";
            tip.domStyle = tip.domStyle + "background-color:#FCFCFC; border-radius:4px 4px; color:#FFF; ";
            tip.domStyle = tip.domStyle + "border-style:solid;border-color:#A3A3AF;border-width:3; z-index:1000;";
            Chart1.tools.add(tip);
            tip.ongettext = function (tool, text) { return '<font face="verdana" color="blue" size="1">' + "Text:\n" + text + '</font>'; }
            Chart1.legend.visible = false;
            Chart1.draw();
        function resize(chart) {
            var canvas = chart.canvas;
            var width = 80, height = 70;
            var w = width * window.innerWidth / 100;
            var h = height * window.innerHeight / 100;
            canvas.width = w;
            canvas.height = h;
            chart.bounds.width = w;
            chart.bounds.height = h;
            chart.draw();
        window.addEventListener('resize', function () {
            if (Chart1 != undefined)
                resize(Chart1);
        }, false);
    </script>
</head>
<body onload="draw()" >
    <div class="class=" col-md-12">
        <center>
            <br><canvas id="canvas" width="1240" height="460">
            </canvas>
        </center>
    </div>
</body>
</html>
Re: Tooltip is slow
Post by Yeray » Wed Jun 29, 2016 9:35 am
I've modified a line of your code, because I believe it was wrong. From:
To:
<div class="col-md-12">
Now, I see in the css you are setting the canvas to use the 90% of the given width:
#canvas {
            width: 90%;
If you remove that part, I believe everything works fine. And If you draw the zoom rectangle with the mouse, you'll see it is drawn in an incorrect place.
So I believe the width:90% is breaking the cursor coordinates given to the chart.
