Jim Green
Post
by Jim Green » Wed Sep 10, 2014 5:05 pm
Hi, when I first started with Tee.js, I had trouble showing a chart sized to all of its parent with {width: 100%; height: 100%;}. This was addressed with some JS code on the body.resize event:
function resize() {
var body = document.body;
var canvas = Chart1.canvas;
canvas.width = body.clientWidth;
canvas.height = body.clientHeight;
Chart1.bounds.width = canvas.width;
Chart1.bounds.height = canvas.height;
Chart1.draw();
I now need to print a chart that occupies the entire page and I am again seeing the same issue: only a portion of the chart prints, as though it thinks it is larger than its parent. This can be seen in the attached ChartPrint.html. (You'll need to adjust the Teechart.js link in ChartSource.html) Open and go to Print Preview. I've tried this in Chrome, FF, and IE9.
Any help appreciated.
Jim
- ChartPrint.zip
- Open ChartPrint.html.
- (1.95 KiB) Downloaded 1155 times
Jim Green
Post
by Jim Green » Thu Sep 18, 2014 8:08 pm
Hello, were you able to reproduce this?
Jim
- Site Admin
Post
by Yeray » Fri Sep 19, 2014 3:33 pm
Hi Jim,
I've printed this using a pdf virtual printer (
PDFCreator), Chrome 37.0.2062.120m and teechart.js
here.
Find attached the resultant pdf. Isn't it correct?
Jim Green
Post
by Jim Green » Fri Sep 19, 2014 3:49 pm
Isn't it correct?
The printout does not show years 2025-28. Other elements (title, axis title, legend) are also shifted to the right.
TeeChart seems to think that the Canvas area is wider than it really is.
Jim
- Site Admin
Post
by Yeray » Mon Sep 22, 2014 9:20 am
Hi Jim,
I think I see what's happening.
In ChartPrint.html you have this:
@media print {
.chartDiv {
width: 10in;
height: 7in;
If you have the ChartPrint.html taking more than 10x7 inches, the chart seems to be cut to 10x7.
I'm investigating if there's a way to propagate this size to the chart in ChartSource.htm and force a repaint on it.
I've tried adding onbeforepaint="resize();" at the body but it doesn't seem to make it work.
- Site Admin
Post
by Yeray » Tue Sep 23, 2014 7:30 am
We found
this solution works fine to make this work.
var beforePrint = function() {
Chart1.draw();
var afterPrint = function() {
if (window.matchMedia) {
var mediaQueryList = window.matchMedia('print');
mediaQueryList.addListener(function(mql) {
if (mql.matches) {
beforePrint();
} else {
afterPrint();
window.onbeforeprint = beforePrint;
window.onafterprint = afterPrint;
Jim Green
Post
by Jim Green » Tue Sep 23, 2014 1:53 pm
Yes, it does seem to work, but so far only in Chrome
The chart is still cutoff in Firefox 32 and IE 9. What did you test it with?
Thanks for the help!
Jim
