I installed 10.3.3 so I had to reinstall both Fast Reports and TeeCharts. After installing and opening up my program, all my charts and series are missing from my forms. I restored my FMX files from last week and they are still not there. Verified my library paths are correct.
What could have caused this and how do I fix it? I have uninstalled and reinstall to no avail.
Charts missing after reinstalling 2020.29
Re: Charts missing after reinstalling 2020.29
Are you getting any error message?
Can you drag a new TChart component into a new form in a new project?
I can drag a regular chart, but when I dray a Chart3d, it only shows in the Structure, not the form. I can double click it and create series, but again, it doesn't show on the form on a new project.
I get no error message starting Delphi or opening my project. Only when I try to compile it, Delphi wants to remove it. On the new project, it will compile but the chart is not visible on the form.
Sorry for the multiple posts. I wanted to let you know, Fast Reports Preview disappeared also. I am working with them too. So, it might be a Fast Report problem. I was able to put a preview on a new project, though it is not displaying properly. See the attachment.
- 2020-04-17_0037.png (31.25 KiB) Viewed 37186 times
I think I will just uninstall everything and go back to Delphi 10.3.2. Everything was fine there. Hopefully, I didn't break my program.
I decided to install just 10.3.3 and TeeChart and not to install Fast Reports. When I started up my app in 10.3.3, I ignored all the errors of the missing Fast Reports. The DBCharts, I have two, didn't display in my program. Not sure what the problem is with 10.3.3 and TeeCharts, but it is just not working. I even tried to install older versions of TeeChart with the same results.
I can create a new project though and drop in a DBChart and it does display. Just not in the current app I have coded in 10.3.2. So for now, I have to uninstall everything and go back to 10.3.2 and hopefully my program is not broke.
At first, it was even working in 10.3.2 even though I restored last weeks fmx's and the pas from history. So I restored from Carbonite AND MY CHARTS ARE BACK TO NORMAL. It is kinda weird. Any idea why the history files would work but the Carbonite files did?
Now I will try to uninstall everything again and then try 10.3.3 again and let you know.
Got everything working now in 10.3.3. Thank you for your help.
Sorry for the delay here.
It may be a case of wrong paths (rubbish produced by multiple installs and uninstalls). I'd have suggested you check the HowTo setup Paths in the IDE post.
Anyway I'm glad to hear it's working for you.
