Pixaleted fonts on axis -> Delphi Seattle
Posted: Wed Sep 16, 2015 7:25 am
by 16570420
Hi
I am using Delphi Seattle
(great version too)
was using XE6
I notice now that the font quality on the axis on tchart on FMX is not very good (compared to how it was in XE6)
especially when smaller font size is used
and it really shows up badly pixaleted when you make the form scale larger (i.e if its on a tlayout and you set the scale of that higher than 1)
I tried playing around with the quality settings in the labelsfont setting but that did not help
what am I missing?
(in testing I see the same thing occurs in XE7 (but XE6 is OK)
thanks!
Brian Hamilton
Re: Pixaleted fonts on axis -> Delphi Seattle
Posted: Wed Sep 16, 2015 11:46 am
Hello Brian,
Have you tried the latest TeeChart version v2015.16 in RAD XE6 to check if the problem is in the IDE or in the component?
I've made a simple test and this is how it looks with RAD 10 and TeeChart v2015.16:
- FMXSmallFont.png (20.63 KiB) Viewed 17123 times
Posted: Wed Sep 16, 2015 12:03 pm
by 16570420
Hi
the issue is when its on a tlayout and that is then increased in scale
e.g via a spinbox
layout1.Scale.x:=layout1.Scale.x+spinbox1.Value/10;
layout1.Scale.y:=layout1.Scale.y+spinbox1.Value/10;
I could duplicate the problem with your test project
Posted: Wed Sep 16, 2015 6:50 pm
by 16570420
Hi
I have attached this test project to show the problem and pictures
Posted: Thu Sep 17, 2015 8:01 am
Thanks for reporting it. I've added it to the public tracker to be further investigated:
http://bugs.teechart.net/show_bug.cgi?id=1309
Posted: Thu Sep 17, 2015 6:42 pm
by 16570420
great
thanks for the great support
I am surprised no one has come across this problem before, seeing that its been there since XE7 (i.e the problem occurs in XE7 too)
(now that I am using DX as my main IDE thats when I noticed the problem
hopefully you can figure out what has changed from the XE6 version of the component
Posted: Fri Sep 25, 2015 5:25 am
by 16570420
Hi
just wondering if there is any update on this issue?
thanks!
Brian
Posted: Fri Sep 25, 2015 2:01 pm
Hello Brian,
You are free to add your mail to the CC list of any ticket in bugzilla so you can be automatically notified when an update arrives.
