The ChartView would gone when pan data
xwTech
Post by xwTech » Fri Nov 11, 2011 5:58 am
I've used the Android demo. For the line serie ,I add it some values like this,
String[] str2 = new String[]{"a","b","c","d","e","f","g","h","i","j"};
				for (String s:str2) {
					series.add(s);
and I select the Tool to PanData, drag the serie to left untile the serie was invisible .
Then the chartView would gone. Is it a bug????
Re: The ChartView would gone when pan data
Post by Yeray » Mon Nov 14, 2011 2:37 pm
There are several overrides of the "add" method. The override that accepts just an string as parameter adds a new null point with specified text. This is its signature:
public int add(final String text)
So with the code above you are adding 10 null points.
I'd suggest you to take a look at the demos and the tutorials.
