evaluation watermark
Bizeasset
Post by Bizeasset » Mon Aug 01, 2011 1:01 am
Hi.
We have paid for and recived a version that still seems to have the watermark. How do we remove it? Please note we used the valuation copy and installed over it with the paid verison (TeeChart Java with Android with source code).
Chris
Bizeasset
Australia.
Re: evaluation watermark
Post by Yeray » Tue Aug 02, 2011 10:01 am
We've checked it and everything seems correct. When we use the TeeChart.Android.jar from an evaluation installation in a testing application, the watermark is shown. When we change (in the same testing application) the TeeChart.Android.jar reference to the jar in a "with sources" installation, the watermark disappears. The watermark isn't shown either linking the testing application directly to the sources "src\Android" instead of using any .jar.
Could you please check that the reference has been correctly updated?
FYI: I've split the thread because it looks more related to a problem with the references in your project than a problem with the release announcement itself. I hope it won't bother you.
