Legends and Tooltips
Perbit
Post by Perbit » Fri Jun 13, 2014 9:20 am
Thank you for your answer :)
Now I have a question about Legends and Tooltips:
I want to limit the number of Legend Entries - but these Entries, which were affected by limitation should be viewable through an "Legend-Tab". That means there should be a symbol right of the entries, I can tab on it, and then I should see the remaining Legend Entries.
An Example:
Thank you Yeray.
Re: Legends and Tooltips
Post by Yeray » Fri Jun 13, 2014 10:01 am
I've split this question into a new thread because it looks as a totally different one.
This comes from this thread
Please read the instructions in my signature for the benefit of all the community.
We'll give you an answer to the technical question asap.
Post by Yeray » Fri Jun 13, 2014 2:02 pm
Hello again,
You could hide the main legend and then use 2 dummy series (hidden and with a subset of the point in the main series). Then you could use 2 ExtraLegend tools and show these legends. Here you have a simple example:
		Pie pie1 = new Pie(tChart1.getChart());
		pie1.fillSampleValues();
		pie1.setCircled(true);
		Pie dummy1 = new Pie(tChart1.getChart());
		Pie dummy2 = new Pie(tChart1.getChart());
		dummy1.setVisible(false);
		dummy2.setVisible(false);
		for (int i=0; i<pie1.getCount(); i++) {
			if (i<4)
				dummy1.add(i, pie1.getYValues().getValue(i), pie1.getLabels().getString(i), pie1.getValueColor(i));
				dummy2.add(i, pie1.getYValues().getValue(i), pie1.getLabels().getString(i), pie1.getValueColor(i));
		extraleg1 = new ExtraLegend(tChart1.getChart());
		extraleg1.setSeries(dummy1);
		extraleg1.getLegend().setAlignment(LegendAlignment.BOTTOM);
		extraleg1.getLegend().setCustomPosition(true);
		extraleg1.getLegend().setLeft(60);
		extraleg1.getLegend().setTop(600);
		extraleg2 = new ExtraLegend(tChart1.getChart());
		extraleg2.setSeries(dummy2);
		extraleg2.getLegend().setCustomPosition(true);
		extraleg2.getLegend().setLeft(310);
		extraleg2.getLegend().setTop(545);
		extraleg2.getLegend().setVisible(false);
		tChart1.addChartMouseListener(new ChartMouseAdapter() {
			@Override
			public void backgroundClicked(ChartMouseEvent e) {
				if (extraleg1.getLegend().clicked(e.getPoint()) > -1) {
					extraleg2.getLegend().setVisible(!extraleg2.getLegend().getVisible());
