how to set mouse Events for markstip in TChart
Jonathan
Post by Jonathan » Fri Sep 18, 2009 9:06 pm
I have a class called 'glassPane' which encases TChart components and intercepting all event handing for the encased component. Since the 'glassPane' intercepts all mouse events, the labels of points in my scatter chart do not get displayed when mouse moves over the points. Thus, I have to pass the mouse (move) events to TChart from glassPane in order to display the markstip labels. So, I did it. However, it doesn't work as I'd expected. Pls. help me how to set mouse event within TChart correctly to display the labels over the scatter points.
Within TChartRenderer, I set the mouse events as followings:
@Override
public void mouseMoved(java.awt.event.MouseEvent e) {
  teeChart.mouseMoved(e);
Re: how to set mouse Events for markstip in TChart
Post by Narcís » Mon Sep 21, 2009 8:33 am
Hi Jonathan,
You can do something as in the example I posted here.
Hope this helps!
Jonathan
Post by Jonathan » Mon Sep 21, 2009 2:32 pm
Hi Narcis,
I'll consider your example.
BTW, Is there a way to re-fire event to TChart? In other words, is it impossible to fire the event directly to TChart? (If so, I don't have to worry about the workaround)
Post by Narcís » Mon Sep 21, 2009 2:45 pm
Hi Jonathan,
Yes, continuing in the example at the thread I pointed you should be able to create MouseEvent variable and pass it onto the mouse event handling method, for example:
        MouseEvent e = new MouseEvent(/*you'll need to add the params here*/);
        tChartMouseListened(e);
Hope this helps!
Jonathan
Post by Jonathan » Mon Sep 21, 2009 4:37 pm
Hi Narcis,
I am using Markstip to display custom labels(in string) for each point. Your "tChartMouseListened(e)" function doesn't do what I need since it displays the value of the point, not labels that are stored previously. I need to display the custom labels when mouse moves over the point.
In my code below, I can get both the index and custom label of the point within mouseMove listener. After that, how can I display the label ?
Points p = new Points(teeChart.getChart());
p.add(3,6);
p.add(4,7);
p.add(5,10);
StringList sl = new StringList(3);
sl.setString(0, "one one");
sl.setString(1, "two two");
sl.setString(2, "three three");
p.setLabels(sl);
MarksTip mt = new MarksTip(teeChart.getChart());
mt.setStyle(MarksStyle.LABEL);
@Override
	int index = teeChart.getSeries(0).clicked(e.getX(), e.getY());
	if(index != -1){
		String str = teeChart.getSeries(0).getMarkText(index);
Post by Narcís » Tue Sep 22, 2009 8:49 am
Hi Jonathan,
In that case you can try this:
      String str = teeChart.getSeries(0).getLabels().getString(index);
Hope this helps!
Jonathan
Post by Jonathan » Tue Sep 22, 2009 2:20 pm
You missed my point. I want to know how to display the custom label when MOUSE MOVES OVER THE POINTS.
Post by Narcís » Tue Sep 22, 2009 3:13 pm
Hi Jonathan,
I'm sorry if my explanation was not clear enough I meant that you should just replace that line in the code snippet you posted. You should replace this:
with this:
so that mouseMoved event is implemented like this:
@Override
   if(index != -1){
Jonathan
Post by Jonathan » Tue Sep 22, 2009 3:30 pm
Hi Narcis,
I understood your previous answer. But, it wasn't the answer I was looking for. I guess my question wasn't clear.
The previous code within mouseMove event doesn't do anything except having index and label values. I don't want to print the label, but want to DISPLAY the label on the scatter chart when mouse moves over the points. I am asking you how to do this.
In my option, it would be best to pass the event to the marktips.mouseEvent(). However, I don't know how to pass java.awt.event.MouseEvent to FrameworkMouseEvent due to lack of API doc. Pls. guide me how to do this.
@Override
   if(index != -1){
         FrameworkMouseEvent fme = new FrameworkMouseEvent(e.getComponent(),e.getID(),e.getWhen(),e.getModifiers(),
                                                     e.getX(), e.getY(), e.getClickCount(), e.isPopupTrigger());
         mt.mouseEvent(fme, Cursor.getDefaultCursor());   // <--- this doesn't work
Post by Narcís » Wed Sep 23, 2009 9:40 am
Hi Jonathan,
MarksTip tool already does this for me only using this code you posted:
        Points p = new Points(tChart1.getChart());
        p.add(3,6);
        p.add(4,7);
        p.add(5,10);
        p.setLabels(sl);
        MarksTip mt = new MarksTip(tChart1.getChart());
Anyway, you can also do this manually using annotation tools or custom drawing on charts canvas, for example:
    private void initChart() {
        p.add(3,6);
        p.add(4,7);
        p.add(5,10);
        p.setLabels(sl);
        tChart1.addMouseMotionListener(new MouseMotionListener() {
            public void mouseDragged(MouseEvent e) {
            public void mouseMoved(MouseEvent e) {
    private void tChartMouseListened(java.awt.event.MouseEvent e) {
        Series s = tChart1.getSeries(0);
        int index = s.clicked(e.getX(),e.getY());
        if (index != -1) {
            String yVal = String.valueOf(s.getYValues().getValue(index));
            String label = s.getLabels().getString(index);
            tChart1.getTools().clear();
            Annotation annotation1 = new Annotation(tChart1.getChart());
            annotation1.getShape().setCustomPosition(true);
            annotation1.getShape().setLeft(e.getX());
            annotation1.getShape().setTop(e.getY());
            annotation1.setText(yVal + " - " + label);
If this doesn't help please attach a simple example project we can run "as-is" to reproduce your problem here.
Jonathan
Post by Jonathan » Fri Sep 25, 2009 9:11 pm
Hi Narcis,
Does this annotation tool work with multiple series on one scatter chart? It seems it doesn't. Say, I have two series of point. I see the tooltip on the 1st series, but not on the 2nd series. Any idea? (BTW, my annotation implementation is same as what you described above.)
thanks,
Post by Narcís » Mon Sep 28, 2009 7:51 am
Hi Jonathan,
Yes, but you should modify mouse event code a little bit to use all series in the chart, for example:
        for (int i = 0; i< tChart1.getSeriesCount(); i++)
            Series s = tChart1.getSeries(i);
            if (index != -1) {
                break;
Jonathan
Post by Jonathan » Mon Sep 28, 2009 2:33 pm
Hi Narcis,
In fact, I have done exactly what you said above.
1) When I display two series in different chart( series A in Chart A, series B in Chart B), then I can see tooltips from both charts.
However,
2) When I display the two series on the same chart (series A and B in Chart A), then I can see tooltips only from series A, not series B). Is this a bug? (FYI - When I printed out the label within tChartMouseListened function, I can see the labels printed out from series A and series B. However, the labels from series B do not get displayed.)
Post by Narcís » Mon Sep 28, 2009 2:36 pm
Hi Jonathan,
Code below works fine for me here. Can you please check if it works fine at your end? Can you please modify the code snippet or send us a simple example project we can run "as-is" to reproduce the problem here?
        p.add(3,6);
        p.add(4,7);
        p.add(5,10);
        p.setLabels(sl);
        Points p2 = new Points(tChart1.getChart());
        p2.add(0,6);
        p2.add(1,7);
        p2.add(2,10);
        StringList sl2 = new StringList(3);
        sl2.setString(0, "one");
        sl2.setString(1, "two");
        sl2.setString(2, "three");
        p2.setLabels(sl2);
            if (index != -1) {
                break;
Jonathan
Post by Jonathan » Mon Sep 28, 2009 6:27 pm
Interestingly, it works when I added "break;" at the end of the code. I appreciate with all of your support.
