Exception raised while getting Mark Coordinates...
Thangaraj
Post by Thangaraj » Fri Mar 26, 2004 2:08 pm
Hi there,
I am using Teechart Pro Ax v6,
I am trying to get marks coordinates and dimensions, for this I use the following in VC++
double x = m_TChart.Series(i).GetMarks().GetPositions().GetPosition(j).GetLeftTop().GetX();
This statement works fine for single series chart.
But for multi-series chart, except for value i=0;j=0; Teechart throws an exception for all values of i and j.
Kindly let me know what is wrong and how I can work around this....
Thangaraj A.L.
Thangaraj A.L.
Post by Pep » Sun Mar 28, 2004 10:59 pm
Hi Thangaraj,
using the following code (with the latest TeeChart Pro v6.04) works fine here, could you please test it ?
void CGetXSeriesMarksDlg::OnButton1()
	for (int i=0;i<=m_chart.GetSeriesCount()-1;++i)
		for (int j=0;j<=m_chart.Series(i).GetCount()-1;++j)
			int a =m_chart.Series(i).GetMarks().GetPositions().GetPosition(j).GetLeftTop().GetX();
			CString s;
			s.Format(_T("%d"), a);
			MessageBox(s);
Thangaraj
Post by Thangaraj » Mon Mar 29, 2004 8:40 am
Thanks Pep
The sample you gave showed me where I was going wrong. The problem was - I was using Tchart.Series(i).GetYValues().GetCount(), instead of TChart.Series().GetCount()
Thanks again....
Thangaraj A.L.
