Teechart .Tee to .Ten conversion tool
Posted: Sun Apr 28, 2024 1:06 pm
by 16695121
Hi Team,
If you have any tool to convert .Tee file to .Ten conversion in C++ would be helpful
Thanks!
Srikanth Ananthoju
Re: Teechart .Tee to .Ten conversion tool
Posted: Mon Apr 29, 2024 9:58 am
Sorry for the delayed reply.
There's a tool to convert .tee to .ten files you can read about here.
Posted: Mon May 06, 2024 10:05 am
by 16695121
Thanks for the reply Yeray
I am still not clear on implementation of TeeChart conversion with the existing ActiveX Control with the resources provided,it would be more helpful if there is anything that helps us to migrate to TeeChart for .Net or TeeChart for JavaScript.
I am looking for an alternative way to use existing tee file and generate an XML file which can be as input for .Net Teechart and JS TeeChart
Thanks!
Srikanth Ananthoju
Posted: Wed May 08, 2024 7:55 am
by Pep
Hello Srikanth,
what is the problem using the TeeToTen tool that my colleague Yeray commented ?
This should the best way to convert from ActiveX to Net.
Best regards,
