Problem with copy/paste and resize new control
PhG47
Post by PhG47 » Wed Apr 12, 2017 12:46 pm
I have a problem with "TeeChart on 2017 Pro ActiveX" and the function to Copy/Paste to duplicate the control over the same form Access or over another form. The function to Copy/Paste distorts the control "TeeChart". After collage, the graphic contents of the control do not follow anymore the dimensions of his container...
You can reproduce the problem so:
- "Examples\MSOffice\VBA Access"
- Go to the design view
- Click to select the control TeeChart on Access Form
- To modify the size of the control with the mouse... the contents and the control resize together
- to Copy the control with "ctrl + c"
- to Paste the control with "ctrl + v"
- to Modify the size of the new control with the mouse... the contents keep his size and the container of the control resize alone.
You can correct this problem
Best regards
Philippe
Re: Problem with copy/paste and resize new control
Post by Yeray » Thu Apr 13, 2017 7:14 am
Hello Philippe,
I've reproduced the problem so I've added it to the public tracker:
http://bugs.teechart.net/show_bug.cgi?id=1841
