Missing TextAlignment with footer
Posted: Tue Jul 22, 2014 5:22 pm
by 16666668
I'm trying to align some lines of footer text left. If I use:
m_ctrlTeeChart1.GetFooter().SetAlignment(taLeftJustify);
only the footer itself is on the left side of the chart, but the text in the footer is still centered. Therefor I miss a function like SetTextAlignment(...) as it is used for example with legends.
Is there any other way, to align the text left?
Raimund
Re: Missing TextAlignment with footer
Posted: Wed Jul 23, 2014 11:04 am
by Pep
Hello Raimund,
which TeeChart ActiveX version are you using ?
I can't reproduce the problem by using the latest v2014.0.0.1 and following code :
m_chart.AddSeries(0);
m_chart.Series(0).FillSampleValues(5);
m_chart.GetFooter().GetText().SetText("hello World");
m_chart.GetFooter().SetAlignment(0);
Posted: Sun Jul 27, 2014 8:12 am
by 16666668
Hello Pep,
if there are more than one line, the text within the footer is centered. My code is
m_ctrlTeeChart1.GetFooter().GetFont().SetName("Arial");//neu 2013
m_ctrlTeeChart1.GetFooter().GetFont().SetItalic(false);
m_ctrlTeeChart1.GetFooter().GetFont().SetColor(RGB(0,0,0));
m_ctrlTeeChart1.GetFooter().GetText().SetText("the footer ist on the left side\r\nbut\r\nthe text within the footer box is centered!");
The result is:
- result.PNG (4.94 KiB) Viewed 11925 times
I miss a special function "TextAlignment()". With the teeEditor it is possible to left align the footer box and with another bottom to left align the text within the footer box.
Posted: Mon Jul 28, 2014 8:12 am
by Pep
Hello Raimund,
yes, you're correct, due to the last v2014 changes and additions, the TextAligment property and others are hidden on the actual maintenance release.
I've just fixed that and now are available at runtime. There will be available for the next maintenance release, which will be available for download in a shorter time, in a few weeks. In meantime you could set it at designtime, via the Chart Editor.
Sorry for inconvenience this could be caused.
