listcontrol
isheo
listcontrol
Post by isheo » Thu Jun 19, 2014 5:12 am
I created the graph by converting the ActiveX Single Record
This is created by using ListControl, but, like using OLE DB, I would like to show up the data on a monitor with using While( xxxxx.MoveNext = S_OK)
I would like to know how to show up the data on ListControl based on dstAllRecords. Also, I would like to know how to embody insetlem and SetleemText at the source below.
m_Adodc1.SetConnectionString("Provider=OraOLEDB.Oracle.1;Password=PMS123;Persist Security Info=True;User ID=PMS;Data Source=ORA11R;Extended Properties=\"\"");
	m_Adodc1.SetCommandType(1);
	CString SQL;
	CString m_search;
	CString strToday;
	SYSTEMTIME    time;
	::ZeroMemory(reinterpret_cast<void*>(&time), sizeof(time));
	::GetLocalTime(&time);
	strToday.Format (_T("%4d%02d%02d"), time.wYear ,time.wMonth ,time.wDay);
	GetDlgItem(IDC_DAY_INPUT)->GetWindowText(m_search);
	if( m_search == "" ){
		m_search = strToday;
	}else {
	SQL.Format("SELECT TO_DATE(CONCAT(A.ACQSI_DT, MAX(A.ACQSI_HHMM)),'YYYYMMDDHH24MI') AS DATES, A.ACQSI_DT AS ACQSI_DT, MAX(A.ACQSI_HHMM) AS ACQSI_HHMM , A.HH AS HH, A.MM_TYPE AS MM_TYPE , SUM(A.CHRG_DCHG_VAL_KW) AS CHRG_DCHG_VAL_KW \
								FROM (																		 \
									SELECT  ACQSI_DT AS ACQSI_DT,											 \
											ACQSI_HHMM AS ACQSI_HHMM,										 \
											SUBSTR(ACQSI_HHMM,1,2) AS HH,									 \
											CASE WHEN SUBSTR(ACQSI_HHMM,3,2) BETWEEN '00' AND '14' THEN '1'  \
												 WHEN SUBSTR(ACQSI_HHMM,3,2) BETWEEN '15' AND '29' THEN '2'  \
												 WHEN SUBSTR(ACQSI_HHMM,3,2) BETWEEN '30' AND '44' THEN '3'  \
												 WHEN SUBSTR(ACQSI_HHMM,3,2) BETWEEN '45' AND '59' THEN '4'  \
												 END  AS  MM_TYPE,                                           \
												 CHRG_DCHG_VAL_KW AS CHRG_DCHG_VAL_KW                        \
									FROM PMS.EES_CHRG_DCHG_HIST	 WHERE ACQSI_DT = \
									'%s') A				 \
				GROUP BY  A.ACQSI_DT, A.HH, A.MM_TYPE	ORDER BY A.ACQSI_DT, A.HH, A.MM_TYPE", m_search);
	m_Adodc1.SetRecordSource(SQL);
	m_Adodc1.Refresh();
	m_Chart1.Series(0).SetDatasourceType(dstAllRecords);
	m_Chart1.Series(0).SetDataSource((_variant_t)m_Adodc1.GetRecordset());
	m_list.InsertColumn(1, "취득일자", LVCFMT_CENTER, 100);
	m_list.InsertColumn(2, "시간타입", LVCFMT_CENTER, 100);
	m_Adodc1.GetRecordset().MoveFirst();
	int iCount = 0;
	CString str = m_Adodc1.GetRecordset().GetFields().GetItem(COleVariant("DATES")).GetValue();
	CString str1 = m_Adodc1.GetRecordset().GetFields().GetItem(COleVariant("ACQSI_DT")).GetValue();
	int iIndex = m_list.InsertItem(iCount, str, 0);
	m_list.SetItemText(iIndex, 1, str1);
	return TRUE;  // return TRUE  unless you set the focus to a control
P.S. I have a favor to ask of any example if there is DataGrid used in TeeChart.
Re: listcontrol
Post by Yeray » Fri Jun 20, 2014 8:48 am
I'm not sure to understand what can we do at our side here.
You can access the series XValues and YValues arrays, can't you?
If you know how to populate a ListControl given an array of strings, you only should convert XValues and YValues arrays of doubles to arrays of strings and populate your ListControl as you'd do without TeeChart.
