EmailFile() one more question.
hansw
Post by hansw » Tue Dec 09, 2003 9:26 pm
EmailFile() works fine, however it would be more pratical if it is possible to set the email address and actually Send the email progamatically. i.e. as it is now I have to add the mail address and click the send button.
Making it automatic (i.e unattended) can be very handy for programs that need to monitor data and report at regular intervals or upon certain alarm conditions.
Can this be done ?
Hans W
Post by Pep » Wed Dec 10, 2003 10:49 am
Hi Hans,
No, this is not possible using TeeChart properties/methods. It is easy,
however, to use Microsoft MAPI Controls 6.0 VB Controls to create your
own emails with attachments, specifying the address and subject you
like:
Using the MAPI Controls
The messaging application program interface (MAPI) controls allow you to
create mail-enabled Visual Basic applications. MAPI is a set of core
system components that seamlessly connect any mail-enabled or workgroup
application to MAPI-compliant information services. For example, the
Microsoft Exchange messaging system can be connected to most private or
public e-mail systems through the use of MAPI drivers.
In Visual Basic, the MAPI controls are used to interact with the
underlying message subsystem. To use these controls, you must first
install a MAPI-compliant e-mail system like Microsoft Exchange. The
underlying messaging services are provided by the workgroup environment
- the Microsoft Exchange Server running under Windows 95 or Windows NT,
for instance.
Using the MAPI controls involves two steps: establishing a MAPI session
and then using various properties and methods to access and manage an
individual Inbox. For example, create and send a message, include a file
attachment, verify the recipient's address against the e-mail system's
address book, etc.
The MAPISession control signs on and establishes a MAPI session. It is
also used to sign off from a MAPI session. The MAPIMessages control
contains all the properties and methods needed to perform the messaging
system functions described above.
The MAPI controls are invisible at run time. In addition, there are no
events for the controls. To use them you must set the appropriate
properties or specify the appropriate methods.
Note If you attempt to run a program that uses the MAPI controls, make
sure that you have the 32-bit MAPI DLLs installed properly or you may
not be able to perform MAPI functions such as SignOn. For example, on
Windows 95, you must install Exchange during the operating system setup,
or install it separately from the control panel to correctly use MAPI
functions.
Possible Uses
To add messaging functionality to your application.
To create a full-featured electronic mail application.
Using the MAPISession control
The MAPISession control is used to sign in and out of a MAPI session.
Assuming that MAPI services are present, logging in with the MAPISession
control is merely a matter of providing a registered user name and
password. The MAPISession control will determine the electronic mail
settings specified in the operating system and invoke the underlying
message subsystem (the mail server).
Setting MAPISession Properties
You can set the MAPISession properties at design time using the
MAPISession Property Pages. Right-click the MAPISession control and
click Properties to display the Property Pages dialog box.
Setting the MAPISession properties at design time
The UserName and Password properties are used to provide a valid sign-on
to the underlying messaging system. You can either set these properties
at design time or prompt the user at run time. Setting the LogonUI
property to True will provide the user with the sign-on dialog box of
the underlying mail system. If such a dialog box does not exist, this
property will be ignored. You can create a custom dialog box to prompt
the user for this information.
The NewSession property specifies whether a new mail session should be
established. If a valid session is already established, setting the
NewSession property will allow two sessions to run concurrently.
The DownloadMail property specifies whether the user's mail will be
downloaded at the beginning of the current session automatically.
Setting this value to True will download all the user's mail to their
Inbox. Depending upon the mail system and the amount of incoming mail,
this can be a processing-intensive operation. By setting this property
to False, the user can choose to download mail at a later time or set
the interval at which mail is automatically downloaded.
The SignOn and SignOff Methods
Once the UserName and Password properties have been set, use the SignOn
method at run time to begin the MAPI session.
For example:
mpsSession.SignOn
When the session is established, the session handle is stored in the
SessionID property. Depending upon the value of the NewSession property,
the session handle may refer to a newly created session or an existing
session.
To end the session use the SignOff method.
Note The Action property can also be used to sign in and out of a MAPI
session. It is recommended, however, that you use the SignOn and SignOff
methods instead. The Action property is included for compatibility with
earlier versions of Visual Basic.
The SessionID Property
When the SignOn method is used to successfully establish a messaging
session, the SessionID property will return a unique messaging session
handle. The SessionID value will be used by the MAPIMessages control to
create an association with a valid messaging session. By default, this
value is 0.
Using the MAPIMessages Control
Once you've logged into a messaging session using the MAPISession
control, you use the MAPIMessages control to receive, send, or read
messages from the Inbox which was specified at sign-on time.
The MAPIMessages control provides you with properties and methods to
perform basic electronic mail tasks. For example, composing a message,
addressing it to a recipient, verifying that the recipient's address is
valid, or attaching a file.
In most cases, the MAPIMessage control is used to provide e-mail
capabilities to certain functions within an application. For example,
you may want to send a notification message to a workgroup alias after
your application has automatically created a report. In other words, you
can add e-mail capabilities to your application, without creating
full-fledged e-mail applications.
You can, however, use the MAPI controls to create very powerful
mail-enabled and workgroup applications.
Sample Application: VBMail.vbp
The examples in the following sections demonstrate the basic use of MAPI
in Visual Basic. For more detailed use of the properties and methods of
the MAPI controls refer to the VBMail.vbp sample application, which is
listed in theSamples directory.
Note You can also use the OLE Messaging technology to add MAPI
functionality to your application. Information on OLE Messaging can be
found in the Microsoft Exchange Software Development Kit.
Associating SessionID Properties
The SessionID property of the MAPIMessages control contains the
messaging session handle returned by the SessionID property of the
MAPISession control. To associate the MAPIMessages control with a valid
messaging session, set this property to the SessionID of a MAPISession
control that was successfully signed on. For example:
mpmMessage.SessionID = mpsSession.SessionID
This association to a valid MAPI session must be made before you can
access messages and begin working with the MAPIMessages control.
Accessing Messages
Successfully logging into a MAPI session accesses the Inbox of the
registered user specified by the UserName and Password properties of the
MAPISession control. The Inbox is the message store. When the Inbox is
opened two buffers are created: the compose buffer and the read buffer.
The read buffer is made up of an indexed set of messages fetched from
the user's Inbox. The MsgIndex property is used to access individual
messages within this set, starting with a value of 0 for the first
message and incrementing by one for each message through the end of the
set.
The message set is built using the Fetch method. The set includes all
messages of type FetchMsgType and is sorted as specified by the
FetchSorted property. The value of the FetchMsgType property is
controlled by the underlying message system. The FetchSorted property
can be set to add messages to the message set (read buffer) in the order
they are received or in the order specified by the user's Inbox.
Previously read messages can be included or left out of the message set
with the FetchUnreadOnly property.
Messages in the read buffer can't be altered by the user, but can be
copied to the compose buffer for alteration.
Messages are created or edited in the compose buffer. The compose buffer
is active when the MsgIndex property is set to -1. Many of the messaging
actions are valid only within the compose buffer, such as sending
messages, saving messages, or deleting recipients and attachments.
Composing and Managing Messages
Managing messages is the primary function of the MAPIMessages control.
Composing, sending, receiving, and deleting messages are performed by
using methods that correspond to these basic functions (compose, copy,
delete, etc.). The following table lists the MAPIMessages methods that
specifically apply to messages:
Method Description
Compose Composes a new message
Copy Copies the currently indexed message to the compose buffer
Delete Deletes a message, recipient, or attachment
Fetch Creates a message set from selected messages in the Inbox
Forward Forwards a message
Reply Replies to a message
ReplyAll Replies to all message recipients
Save Saves the message currently in the compose buffer
Send Sends a message
To perform an action on an individual message, it must first be selected
using the MsgIndex property. The message identified by the MsgIndex
property is called the currently indexed message.
None of the other message properties can be set until a message is
selected with the MsgIndex property. The index number can range from -1
to MsgCount -1 (the MsgCount property returns the total number of
messages in the message set.) When a new message is created, the value
of the MsgIndex property is set to -1.
Composing a Message
Use the Compose method to create a new message. When the Compose method
is used, the compose buffer is cleared and the MsgIndex property is set
to -1.
'Compose new message
mpmMessage.Compose
Completing a message involves several steps: determining the recipient
of the message, choosing a subject title, and writing the message.
Addressing the Message
To set the recipient's name and address, use the RecipDisplayName and
the RecipAddress properties. The RecipDisplayName is the proper name of
the recipient, for example, "Richard Tull". The RecipAddress property
contains the recipient's e-mail address: "richtull", for example.
'Address message
mpmMessage.RecipDisplayName = "Richard Tull"
mpmMessage.RecipAddress = "richtull"
Addresses for recipients outside the local workgroup (a message sent to
someone at another company via the Internet, for example) require a
complete Internet e-mail address: "richtull@littlemag.com".
Verifying the Recipient's Name
The recipient's name is verified when the message is sent by checking it
against the list of registered users in the e-mail system, using the
ResolveName method. Name verification for recipients outside the local
workgroup is handled in various ways by the underlying message system.
The following example resolves the recipient's valid e-mail name by
invoking the ResolveName method and setting the AddressResolveUI
property to True.
' Resolve recipient name
mpmMessage.AddressResolveUI = True
mpmMessage.ResolveName
The AddressResolveUI property can be set to either display a details
dialog box (True) or generate an error (False) when an ambiguous or
invalid recipient address is encountered when the message is sent. The
details dialog box will offer you an alternative address if a close
match is found.
The Message Subject and Text
The MsgSubject property specifies the subject line for the message. You
may enter up to 64 characters, including the Null character.
The body of the message is contained in the MsgNoteText property. For
inbound messages, each paragraph is terminated with a carriage
return-line feed pair (vbCrLf). Outbound messages can be delimited with
a carriage return (vbCr), line feed (vbLf), or a carriage return-line
feed pair.
'Create the message
mpmMessage.MsgSubject = "Status Report"
mpmMessage.MsgNoteText = "Build successful!"
Sending the Message
To send the message, use the Send Method. The Send method allows you to
send a message with or without user interaction. Setting the value to
True will display the compose message dialog box of the underlying
e-mail system (Microsoft Exchange, for example). Setting it to False
will send the message without displaying the compose message dialog. The
following example sends the message without prompting for user
interaction:
'Send the message
mpmMessage.Send False
Handling File Attachments
You can add file attachments to outgoing messages using the file
attachment properties. These properties are listed in the following
table:
Property Description
AttachmentCount Returns the total number of attachments associated with
AttachmentIndex Sets the currently indexed attachment.
AttachmentName Specifies the name of the currently indexed attachment
file.
AttachmentPathName Specifies the full path name of the currently indexed
attachment.
AttachmentPosition Specifies the position of the currently indexed
attachment within the message body.
AttachmentType Specifies the type of the currently indexed file
attachment.
To add an attachment to an outgoing message, use the AttachmentPathName
property to specify the name and path of the file. For example:
'Add attachment
mpmMessage.AttachmentPathName = "c:\Status _
Report.doc"
If the path name is incorrect or empty, an error will be generated.
Simply specifying the AttachmentPathName property will send the
attachment with the message, use the name of the file to display in the
message body, and position the attachment at the beginning of the
message.
The AttachmentName property can be used to specify a different name for
the attached file. If this property isn't set, the actual name of the
file will be displayed in the message body.
The AttachmentPosition property is used to position the attachment
within the message body. By default, the value is "0" and the attachment
is located at the beginning of the message body. To position the
attachment at the end of the message, count the number of characters in
the message body. For example, in a message body that is five characters
long, you could place an attachment at the end of the message by setting
the value to 4. (The message body occupies character positions 0 to 4).
Two attachments can't be placed in the same position within the same
message. You also can't place an attachment equal to or beyond the end
of the message body. You can append an extra space or a vbCrLf character
to the end of the message body and then set the AttachmentPosition
property to one character less than the length of the MsgNoteText
property.
Managing Messages
Many of the remaining properties and methods of the MAPIMessages control
can be used to manage messages just as you would in a full-featured
e-mail application.
By accessing messages in the read buffer you can sort, delete, or
forward one or a number of messages. The following table lists the
properties you can use to manage messages:
MsgConversationID Specifies the conversation thread identification value
for the currently indexed message.
MsgCount Returns the total number of messages present in the message set
during the current messaging session.
MsgDateReceived Returns the date on which the currently indexed message
was received.
MsgID Returns the string identifier of the currently indexed message.
MsgIndex Specifies the index number of the currently indexed message.
MsgOrigAddress Returns the mail address of the originator of the
MsgOrigDisplayName Returns the originator's name for the currently
indexed message.
MsgRead Returns a Boolean expression indicating whether the message has
already been read.
MsgReceiptRequested Specifies whether a return receipt is requested for
MsgSent Specifies whether the currently indexed message has already been
sent to the mail server for distribution.
MsgType Specifies the type of the currently indexed message.
Working with the Address Book
The e-mail system's address book contains all of the addressing
information for each registered user in the e-mail system. The address
book is a dialog box which allows the user to look up or verify
recipient addresses. The address book properties allow you to set or
modify elements of the address book.
The Show Method
The e-mail system's address book is displayed using the Show method. The
Show method can be set to show either the address book or the recipient
details dialog box.
By default, the value is set to False and the address book dialog box is
displayed when the Show method is used.
To display the details dialog box, set the value to True. The amount of
information displayed in this dialog box depends upon the e-mail system.
At minimum, the name and address of the recipient are displayed.
Address Book Properties
The address book properties allow you to set or modify elements of the
e-mail system's address book. The following table lists these
properties:
AddressCaption Specifies the caption appearing at the top of the address
book.
AddressEditFieldCount Specifies which edit controls to display to the
user in the address book.
AddressLabel Specifies the appearance of the "To" edit control in the
address book.
AddressModifiable Specifies whether the address book can be modified by
the user.
AddressResolveUI Specifies whether a dialog box is displayed for receipt
name resolution during addressing.
All of the address book properties can be set at design time using the
MAPIMessages control's Property Pages dialog box.
Setting the MAPIMessages properties at design time
Setting the address book properties at design time allows you to specify
options for the display and functionality of the address book dialog
box. For example, you can modify the caption that appears in the address
book dialog box using the AddressCaption property.
Josep Lluis Jorge
http://support.steema.com
hansw
Post by hansw » Wed Dec 10, 2003 2:47 pm
Josep,
Thanks, I'll look into it.
Hans W
