hi,
I have two datasets in my ASP page and I use OnMouseEnterSeries to display the data value for each of the series in a textarea. I have tried a couple of cases and here are their descriptions:
Case 1:
I use the method only for Series0 and display the data for the two series. When moving the mouse over the datapoint(s) of Series0, the values are displayed correctly. When moving the mouse over Series1, both the values are 2.12199579096577E-311...even though the OnMouseEnterSeries method is not provided for Series1.
sub MyChart_OnMouseEnterSeries(Series0)
dim clicked, strValues
clicked = MyChart.Series(0).GetMousePoint
strValues = ""
strValues = strValues + "R1: " & CStr(MyChart.Series(0).YValues.Value(clicked)) & " mV" & vbNewLine
strValues = strValues + "R2: " & CStr(MyChart.Series(1).YValues.Value(clicked)) & " mV" & vbNewLine
window.frmValue.txtDecay.value = strValues
end sub
Case 2:
I added the second OnMouseEnterSeries method for Series1 and now the page works so that when moving the mouse over Series0 datapoint, both the shown values are 2.12199579096577E-311 and when moving over Series1, both the shown values are correct.
Case 3:
I modified the methods so that when moving the mouse over Series0, it should show only the data value of Series0 data point (.Series(0).YValues.Value(clicked)) and similarly, when moving the mouse over Series1, only the data value of Series1 data point is shown (.Series(1).YValues.Value(clicked)). HOWEVER, the actual shown data values are: 2.12199579096577E-311 when moving over Series0 and the correct value when moving over Series1.
Case 4:
I switched the two methods so that the OnMouseEnterSeries(Series1) is now defined BEFORE OnMouseEnterSeries(Series0) and the functionality described in Case 3 is now vice versa. It seems that only the function that has been defined last in the source code works correctly.
What should I do to implement the feature that when moving the mouse over any of the dataseries (data points), the data values of all series are shown correctly?
Thanks in advance for any advice
Mike
OnMouseEnterSeries problem
Hi Mike,
You could try using code similar to the following (please excuse the VB.6.0 code -- this should be easy to implement in VBScript/ASP):What should I do to implement the feature that when moving the mouse over any of the dataseries (data points), the data values of all series are shown correctly?
With TChart1
.AddSeries scPoint
.AddSeries scPoint
.Series(0).FillSampleValues 10
.Series(1).FillSampleValues 10
End With
Private Sub TChart1_OnMouseMove(ByVal Shift As TeeChart.EShiftState, ByVal X As Long, ByVal Y As Long)
Dim Series0, Series1
With TChart1
Series0 = .Series(0).Clicked(X, Y)
Series1 = .Series(1).Clicked(X, Y)
If Series0 <> -1 Then
Label1.Caption = .Series(0).YValues.Value(Series0)
End If
If Series1 <> -1 Then
Label1.Caption = .Series(1).YValues.Value(Series1)
End If
End With
Thank you!
http://groups.google.com
http://codenewsfast.com/
hello Christopher,
Thanks for your response. However, by trying out your code the graph was displayed correctly, but nothing happened during mouse movement over the chart.
Are all OnMouseMove, OnMouseEnterSeries, OnMouseLeaveSeries etc. functions fully usable also in VBScript, when using the .tee file as providing the chart to the client side?
TIA
Mike
TIA
Mike
Hi Mike,
[url]news://www.berneda.com/steema.public.attachments[/url]
No. I have attached a working ASP/HTM example of the VB code I sent you earlier to:Are all OnMouseMove, OnMouseEnterSeries, OnMouseLeaveSeries etc. functions fully usable also in VBScript, when using the .tee file as providing the chart to the client side?
Thank you!
cannot download attachments
hi,
I found your attachments, but cannot download them due to
"OE removed access to the following unsafe attachments in your mail:...."
My settings or server's settings?
.-= Mike =-.
.-= Mike =-.
Hi Mike,
. In OE go to Tools -> Options -> Security -> Do not allow attachments to be saved or opened that could potentially be a virus.
Your settingsI found your attachments, but cannot download them due to
![Very Happy :D](./images/smilies/icon_biggrin.gif)
Thank you!
