Bug 978 - The Titles, Position, Custom positioning does not set the position of the title
Summary: The Titles, Position, Custom positioning does not set the position of the title
Version: 140923
Reported: 2014-10-23 02:55 EDT by Ian Schirmer
Modified: 2014-11-03 09:30 EST (History)
Description Ian Schirmer 2014-10-23 02:55:08 EDT
The Titles, Position, Custom Left and Right boxes do not set the position of the title.  The only method is to see them in the run time code or manually edit the dfm file.
Comment 1 Ian Schirmer 2014-10-23 02:56:15 EDT
This function will work sometimes, however mostly will not.
Comment 2 sandra pazos 2014-10-27 05:19:31 EDT
Hello Ian,
The problem you are experiencing doesn't appear using the code below:
uses Series;
var Series1 :TLineSeries;
    Series1 := TLineSeries.Create(self);
    Chart1.AddSeries(Series1);
    Series1.FillSampleValues(10);
    Chart1.Title.CustomPosition := true ;
    Chart1.Draw;
    Chart1.Title.Left := 150;
    Chart1.Title.Top := 100;
Could you please check if my code works as you want?
Thanks in advance,
Regrads
