Bug 974 - XE7: TChart on FMX TabControl hangs using "slide" animation
Summary: XE7: TChart on FMX TabControl hangs using "slide" animation
Product: FireMonkey TeeChart
Reported: 2014-10-22 05:36 EDT by yeray alonso
Modified: 2014-10-22 10:36 EDT (History)
test error (58.48 KB, application/octet-stream)
2014-10-22 05:36 EDT, yeray alonso
Description yeray alonso 2014-10-22 05:36:41 EDT
Created attachment 311 [details]
test error
"Using the attached demo, make sure "TabItem1" is the selected tab at design-time; Run the app; click "Button2" to active "TabItem2" with the "Slide" animation;
If the "Chart1" is made visible by either setting "TabItem2" as selected at design-time, or by clicking "TabItem2" directly at run-time, then the "slide" transition will work (won't hang the app) from then on."
Using the actual sources, the app crashes at TTeeCanvas3D.ReDrawBitmap the second time it's called. FCanvas isn't nil (it was with v2014.12),  TTeeCanvas3D.TransferBitmap is called and it crashes in the line:
  ACanvas.DrawBitmap(FBitmap,RectF(0,0,FBitmap.Width,FBitmap.Height),
     RectF(ALeft,ATop,
           ALeft+{$IFDEF FMXSCALE}Round(FBitmap.Width/ACanvas.Scale){$ELSE}FBitmap.Width{$ENDIF},
           ATop +{$IFDEF FMXSCALE}Round(FBitmap.Height/ACanvas.Scale){$ELSE}FBitmap.Height{$ENDIF}),
     1 {AbsoluteOpacity},
     True);
Call Stack:
System._ROUND
:00407253 System::__linkproc__ ROUND()
FMXTee.Canvas.TTeeCanvas3D.ReDrawBitmap
FMXTee.Procs.TCustomTeePanel.Paint
FMX.Controls.TControl.PaintInternal
The problem may be ACanvas.Scale value: 7.81101302442025e-35; the first time TTeeCanvas3D.ReDrawBitmap is called Scale value is 1 and it works fine.
