Bug 958 - Disable Hover by default
Summary: Disable Hover by default
Version: 140923
: High enhancement
Reported: 2014-10-10 05:19 EDT by yeray alonso
Modified: 2014-10-20 10:16 EDT (History)
Description yeray alonso 2014-10-10 05:19:51 EDT
As the customer says in the forums, the hover feature is modifying the behaviour of old projects.
We could do what we did with GDIPlus: add an option at the "New Chart" tab in the design time options that writes a key in the registry.
Then Hover could be disabled when this key isn't set, meaning that's an old chart.
Comment 1 david berneda 2014-10-10 13:10:37 EDT
The problem with a registry setting is, when the exe moves to another PC, the setting is not there.
This setting could be used for new Charts added at design-time, but not for existing ones.
Is there any example? Can we fix this?
There is a global per-chart setting to disable Hover:
  Chart1.Hover.Visible:=False;
Comment 2 yeray alonso 2014-10-20 10:16:12 EDT
We can't consider this as a bug to be fixed. It's a new feature important enough to be enabled by default.
We consider we haven't broken backwards compatibility because the charts made with previous versions still work.
And, there's a simple call that can be added to existing projects to disable this feature when undesired.
