Bug 951 - White space between the slices in concentric Pie/Donut
Summary: White space between the slices in concentric Pie/Donut
Status: IN_PROGRESS
Version: 140923
Hardware: Other Other
: --- minor
Reported: 2014-10-08 07:58 EDT by yeray alonso
Modified: 2015-04-23 06:58 EDT (History)
Chart Series: Pie
Delphi / C++ Builder RAD IDE Version: Delphi 7
Description yeray alonso 2014-10-08 07:58:27 EDT
Having  Concentric TPieSeries/TDonutSeries without Pen, there's a little white
space drawn between the slices
uses Series, TeeDonut;
var i, j: Integer;
  Chart1.Legend.Visible:=false;
  for i:=0 to 9 do
    //with Chart1.AddSeries(TPieSeries) as TPieSeries do
    with Chart1.AddSeries(TDonutSeries) as TDonutSeries do
      MultiPie:=mpConcentric;
      Marks.Visible:=false;
      Pen.Visible:=false;
      for j:=0 to 9 do
        Add(10,'',clBlack);
Comment 1 david berneda 2014-10-10 06:08:34 EDT
Problem due to canvas antialias. Same issue happens with Firemonkey.
A possible workaround is to fill the circle behind the series:
  Chart1.Draw;
procedure TForm1.Chart1BeforeDrawSeries(Sender: TObject);
var p : TPieSeries;
  p:=TPieSeries(Chart1[0]);
  Chart1.Canvas.Brush.Style:=bsSolid;
  Chart1.Canvas.Brush.Color:=clBlack;
  Chart1.Canvas.Ellipse(p.CircleRect);
Another solution is to set the series Pen color to be the same color as the series data color.  The pen antialias will cover the missing pixels.
Comment 2 yeray alonso 2015-04-23 06:58:51 EDT
Both workarounds would work when all the series and all the values have the same color, but not when having different colors. Ie:
uses Series;
var i, j: Integer;
  Chart1.Title.Visible:=false;
  Chart1.Hover.Visible:=false;
  for i:=0 to 3 do
      Pen.Visible:=false;
      for j:=0 to 9 do
          Add(10,'',clNone);
  Chart1[0].ValueColor[0]:=OperaPalette[0];
  Chart1[1].ValueColor[0]:=OperaPalette[0];
  Chart1[0].ValueColor[2]:=OperaPalette[1];
  Chart1[1].ValueColor[2]:=OperaPalette[1];
  Chart1[2].ValueColor[2]:=OperaPalette[1];
  Chart1[0].ValueColor[3]:=OperaPalette[2];
  Chart1[1].ValueColor[3]:=OperaPalette[2];
  Chart1[2].ValueColor[3]:=OperaPalette[2];
  Chart1[3].ValueColor[3]:=OperaPalette[2];
  Chart1[0].ValueColor[5]:=OperaPalette[3];
  Chart1[1].ValueColor[5]:=OperaPalette[3];
  Chart1[0].ValueColor[7]:=OperaPalette[4];
  Chart1[1].ValueColor[7]:=OperaPalette[4];
  Chart1[2].ValueColor[7]:=OperaPalette[4];
  Chart1[0].ValueColor[8]:=OperaPalette[5];
  Chart1[1].ValueColor[8]:=OperaPalette[5];
