Bug 949 - Export theme, huge size if base64 checkbox checked.
Summary: Export theme, huge size if base64 checkbox checked.
Version: TeeChart for .NET 4.1.2013.11080
: --- critical
Reported: 2014-10-08 06:06 EDT by sdgr
Modified: 2014-11-03 09:39 EST (History)
Two screenshots and an exported theme. (1.13 MB, application/x-zip-compressed)
2014-10-08 06:06 EDT, sdgr
Description sdgr 2014-10-08 06:06:07 EDT
Created attachment 299 [details]
Used TeeChart version: .NET 4.1.2013.11082
I have a chart with 7 line series, nothing special.
If I go to the Editor of TeeChart and export the theme
- without series base64, I get a file size = 7Kb
- with series base64, I get a file size = 9Mb !
I attached two screenshots and the exported theme (9 Mb).
Other charts in my application, having also a number of line charts, don't have such huge size.
Can you figure out the reason for this behaviour?
Stefan.
Comment 1 sandra pazos 2014-10-24 08:37:03 EDT
To reproduce the problem loads the client theme with the code below:
Private void Form1_Load(object sender, EventArgs e)
            tChart1.Import.Theme.Load(@"HugeSeries\Chart1.xml");
Comment 2 christopher ireland 2014-11-03 09:39:04 EST
I do not consider this a defect, as the SaveWithBase64 property of the Theme class uses the Template export to export the entire chart to a stream, and then renders this stream as Base64 to save in a text file. I therefore consider the size of this theme as within expected parameters.
