Bug 93 - The pointer of Horizontal Line can't be drawed clearly
Summary: The pointer of Horizontal Line can't be drawed clearly
Status: IN_PROGRESS
Product: FireMonkey TeeChart
Version: 131016
Reported: 2013-11-12 09:31 EST by elmec
Modified: 2013-11-14 09:45 EST (History)
XE4 Firemonkey HD Application (155.40 KB, application/x-zip-compressed)
2013-11-12 09:31 EST, elmec
Description elmec 2013-11-12 09:31:29 EST
Created attachment 17 [details]
There is no Horizontal Point Line,
so I using the Horizontal Line, and set the Pointer as visible,
change the transparency to 100 to hide the line between pointer
to make it just looks like as TPointSeries.
But just like shown in the attachment,
when there are a lot of points ,
they are drawed overlaping each other, cannt be shown clearly.
When I zoomin the series, it became clearly drawed.
BTW, I am using
XE4 Firemonkey HD Application and Teechart201308 for XE4.
Comment 1 narcís calvet 2013-11-12 09:46:09 EST
There's a problem with the bottom axis range. Commenting out the line below points are visible.
	//Chart1->BottomAxis->SetMinMax(-0.3, 0.3);
Comment 2 narcís calvet 2013-11-13 06:02:39 EST
Setting Pointer.Pen.Color to clTeeColor works:
	Series2->Pointer->Pen->Color=clTeeColor;
Comment 3 david berneda 2013-11-13 10:25:44 EST
(In reply to elmec from comment #0)
> BTW, I am using
FireMonkey Direct2D canvas is "blending" pixels when they are painted overlapped using borders instead of filling.
One setting that makes all points visible is to disable the Pointer->Pen like:
 Series2->Pointer->Pen->Hide();
However, I've been trying to discover how to deactivate this "blending" effect.
Setting canvas to GPU does not do blend, but other parts like text don't look good:
// ProjectPointer.cpp
extern "C" int FMXmain()
	try
                GlobalUseGPUCanvas=true;   // <--------- added this line
		Application->Initialize();
Another property that should work fine (but it fails), is setting the form quality to "high performance" to disable pixel "blending":
__fastcall TForm12::TForm12(TComponent* Owner)
	: TForm(Owner)
  Quality=TCanvasQuality::ccHighPerformance;  // <----- this line
I'm investigating why FireMonkey is painting it correctly first time, and then inmediately is painting again with ccHighQuality. Not sure if its a TChart bug or FireMonkey, as it does the same in "XE5 Update 1"
Hope its fine for you to just hide the Pointer->Pen, and we'll investigate how to deactivate "blending" in the near future.
Comment 4 narcís calvet 2013-11-13 10:36:19 EST
(In reply to david berneda from comment #3)
> like:
My previous comment was incomplete. That's only true with psRectangle but fails with psSmallDot.
Comment 5 david berneda 2013-11-14 09:45:28 EST
(In reply to narcís calvet from comment #4)
> > like:
Yes, psSmallDot is currently done with a line pen of length 1.
