Bug 911 - Return value for LoadFromFile
Summary: Return value for LoadFromFile
Status: RESOLVED WONTFIX
Version: 140512
: Low enhancement
Blocks: 912
  Show dependency treegraph
Reported: 2014-09-08 08:08 EDT by yeray alonso
Modified: 2014-09-12 12:39 EDT (History)
Description yeray alonso 2014-09-08 08:08:04 EDT
LoadFromFile method could return a Boolean or a pointer (like normal filehandling) to check this.
A customer would like to check if the file was loaded successfully, wasn't found, was corrupt etc..
Comment 1 david berneda 2014-09-12 12:39:09 EDT
Returning a Boolean will not indicate the exact cause.
Correct behaviour is to raise an exception, being the exception class and properties the info about the problem.
See for example Classes.pas TStrings LoadFromFile:
procedure TStrings.LoadFromFile(const FileName: string);
var
  Stream: TStream;
  Stream := TFileStream.Create(FileName, fmOpenRead or fmShareDenyWrite);
  try
    LoadFromStream(Stream);
  finally
    Stream.Free;
OurTTeeSeriesSourceFile.LoadFromFile, TImportChart.LoadFromFile and TeeStore.pas unit LoadChartFromFile, all use the RTL default TFileStream classes.
A custom function can always "eat" the exception and return a boolean, if desired:
uses
  TeeStore;
function Load(const AChart:TCustomChart; const AFile:String):Boolean;
  try
    LoadChartFromFile(AChart,AFile);
    result:=True;
  except
    on Exception do
      // EAT
      result:=False;
  if Load(Chart1,'test.tee') then
     Caption:='OK'
     Caption:='BAD';
However, this is not recommended. Exceptions must surface-up to callers.
