Bug 909 - Code doesn't compile
Summary: Code doesn't compile
Version: 140512
: Highest blocker
Reported: 2014-09-04 13:56 EDT by g.h.m.laagland
Modified: 2014-09-05 07:11 EDT (History)
3 users (show)
Screen dump showing the installed packages (36.83 KB, image/png)
2014-09-04 13:56 EDT, g.h.m.laagland
Compiler shows assumed error (213.43 KB, image/png)
2014-09-04 13:57 EDT, g.h.m.laagland
Screendump of programs folder (197.45 KB, image/png)
Description g.h.m.laagland 2014-09-04 13:56:01 EDT
Created attachment 283 [details]
I installed Delphi XE6 Enterprise and TeeChart Pro 2014. I migrated the Delphi XE and TeeChart Pro 2010 code and recompiled. This was succesful for application not using TeeChart. Applications with TeeChart did not recompile.
The bug is at TChartPen, which appears to be an unknown type although TeCanvas is in the uses clause and compilation has always been succesful with Delphi XE and TeeChart 2010.
I tried several things with the unit scope names but without any success. With another third party component (dOPC) I had no problems at all.
See the attachment for details.
Comment 1 g.h.m.laagland 2014-09-04 13:57:02 EDT
Created attachment 284 [details]
Comment 2 g.h.m.laagland 2014-09-04 13:57:43 EDT
Created attachment 285 [details]
Comment 3 narcís calvet 2014-09-05 06:48:11 EDT
Please try compiling the code using supplied Recompile tool. It will generate missing FMXTee or VCLTee prefixed units.
Comment 4 yeray alonso 2014-09-05 07:11:34 EDT
I think you don't have TeeChart sources so you can't use TeeRecompile.
Does a new project with just a TChart on the form work fine for you?
- If not, please try reinstalling the component (you can run TeeInstall twice) and check the paths in the IDE.
- If yes, but your old project still fails, please check the paths both in the IDE and in the project.
