Bug 895 - Left Axis Labels Behind checkbox
Summary: Left Axis Labels Behind checkbox
Version: 140512
Reported: 2014-08-25 00:07 EDT by Shinobu Nagai
Modified: 2014-09-15 21:54 EDT (History)
3 users (show)
Axis Labels behind (116.72 KB, image/png)
2014-08-25 00:07 EDT, Shinobu Nagai
Test project (2.65 KB, application/x-zip-compressed)
2014-09-12 12:49 EDT, david berneda
Left axis (17.46 KB, image/png)
2014-09-15 21:40 EDT, Shinobu Nagai
Description Shinobu Nagai 2014-08-25 00:07:29 EDT
Created attachment 270 [details]
Axis Labels behind
Even if I select All Features/Axes/Labels/Axis Labels behind sample and mark/unmark the Left Axis Labels Behind checkbox, I don't see any changes.
Comment 1 narcís calvet 2014-08-28 06:28:52 EDT
It's a problem with the demo. The component works fine in VB6. It can be fixed in the Axis_LabelsBehind example code using this:
Private Sub Check1_Click()
  TChart1.Axis.Behind = Check1.Value
Comment 2 narcís calvet 2014-08-28 06:32:45 EDT
Comment 3 Shinobu Nagai 2014-08-29 01:41:16 EDT
If I set the code, not only left labels but also bottom axis labels are set behind. Is it correct?
Comment 4 narcís calvet 2014-08-29 03:43:38 EDT
Yes, I think so. Behind property is a global axes property, not for each individual axis. I don't think it should be there in the ActiveX version as it doesn't even exists for individual axis in the VCL/FMX version. We will try to fix it for future releases.
Comment 5 pep jorge 2014-09-02 06:55:32 EDT
Nagai, you're correct, this is an VCL bug which we'll try to fix for the next maintenance releases.
The equivalent code in VCL  :
Chart1.Axes.Left.LabelsBehind := False;
does not do nothing.
Comment 6 david berneda 2014-09-12 12:48:54 EDT
It's not technically a bug.
The current functionality of LabelsBehind (or Texts.Behind) is to display the axis labels behind or on top of the axis grid lines.
This is False by default.
What makes axis labels (and grids) to display on-top of series is the Axes.Behind property, which is True by default.
procedure TForm1.CheckBox1Click(Sender: TObject);
  Chart1.Axes.Left.Texts.Behind:=CheckBox1.Checked;
  Chart1.Axes.Left.Grid.Width:=4;
procedure TForm1.CheckBox2Click(Sender: TObject);
  Chart1.Axes.Behind:=CheckBox2.Checked;
I'm adding a test project attachment.
Comment 7 david berneda 2014-09-12 12:49:18 EDT
Created attachment 295 [details]
Test project
Comment 8 Shinobu Nagai 2014-09-15 21:40:16 EDT
Created attachment 297 [details]
Left axis
Comment 9 Shinobu Nagai 2014-09-15 21:54:57 EDT
You mentioned:
Then, please change the demo to easily understand it?
You mentioned:
Please see the attached image. It shows a chart image when I ran your test project. As you see, the both checkboxes are set to False. When setting them to False, both labels and grids should be displayed on-top of the series, shouldn't they? However, they aren't displayed as expected. How can they be displayed on-top of series?
