Bug 893 - AV on opening form with component using TChart
Summary: AV on opening form with component using TChart
Version: 140512
Reported: 2014-08-20 04:52 EDT by yeray alonso
Modified: 2014-09-12 12:59 EDT (History)
test ProjectGroup (61.09 KB, application/octet-stream)
2014-08-20 04:52 EDT, yeray alonso
Description yeray alonso 2014-08-20 04:52:13 EDT
Created attachment 269 [details]
test ProjectGroup
Find attached a ProjectGroup with 2 projects.
One is a simple component with a form and a Chart, and the other is a simple application using that component.
- Open the project Coll.drpoj.
- Build and install the component "Coll"
- Close the project.
- Open the project testApp.dproj. You'll get an AV.
Comment 1 david berneda 2014-09-12 12:59:29 EDT
Test shows the problem is only at design-time. It works at runtime:
uses CollChartPanel;
procedure TForm217.FormCreate(Sender: TObject);
var c: TCollChartPanel;
  c:=TCollChartPanel.Create(Self);
  c.Parent:=Self;
  c.Height:=200;
Probably its needed inside the CollChartPanel component to add code to support inner-controls (similar to our QRTee.pas control) to make it work at design-time.
At design-time, when doing this:
 FChart        := TChart.Create(Self);
The ide tries to add FChart to the Object TreeView, Object Inspector etc and can be confused without adding several methods (and a FChart.Name).
If the purpose is to hide the FChart from the user inside the ide at design-time, the correct way is to use "nil" as owner.
