Bug 812 - Option to export a chart and append it into an existing svg file
Summary: Option to export a chart and append it into an existing svg file
Reported: 2014-06-25 11:09 EDT by yeray alonso
Modified: 2014-06-27 04:55 EDT (History)
Description yeray alonso 2014-06-25 11:09:19 EDT
This option should remove the last line in the existing svg file (the line containing "</svg>") and then add the exported chart into the same file without the header.
Related: Option to set an origin for the chart different than 0,0 so the second chart don't overlap the first one.
Comment 1 yeray alonso 2014-06-27 04:55:09 EDT
New SVGFormat save() function that accepts a Point to start drawing the new chart and a boolean to choose if you want the new chart to be appended into the given fileName or not.
So you'll be able to do this:
try {
  tChart1.getExport().getImage().getSVG().save("E:\\tmp\\testJava1.svg");
  tChart2.getExport().getImage().getSVG().save("E:\\tmp\\testJava1.svg", new Point(tChart2.getX(), 0), true);
} catch (FileNotFoundException ex) {
  Logger.getLogger(ChartJFrame.class.getName()).log(Level.SEVERE, null, ex);
} catch (IOException ex) {
