Bug 801 - Same ValueLists for multiple series
Summary: Same ValueLists for multiple series
URL: http://stackoverflow.com/questions/24...
Reported: 2014-06-16 10:30 EDT by narcís calvet
Modified: 2014-07-16 07:23 EDT (History)
Description narcís calvet 2014-06-16 10:30:45 EDT
Being able to use the same and unique ValueLists for multiple series so data doesn't need to be copied across. Different series could even be in different charts. See the StackOverflow discussion in the URL field.
Comment 1 narcís calvet 2014-07-16 07:23:13 EDT
Revisiting this issue, while it is true that the same series object cannot be added to two different charts, it is also true that the same Arrays can be used by two series each in two different charts, e.g.:
    double[] XValues, YValues;
      YValues[1] = 7;
      ModifySeries(tChart1[0]);
      ModifySeries(tChart2[0]);
      tChart2.Aspect.View3D = false;
      XValues = new double[] { 1, 2 };
      YValues = new double[] { 1, 2 };
      AddNewSeries(tChart1);
      AddNewSeries(tChart2);
    private void ModifySeries(Series series)
      series.YValues.Modified = true;
      series.XValues.Modified = true;
      series.Invalidate();
    private void AddNewSeries(TChart tChart)
      FastLine series1 = new Steema.TeeChart.Styles.FastLine(tChart.Chart);
      series1.YValues.Value = YValues;
      series1.YValues.Count = YValues.Length;
      series1.XValues.Value = XValues;
      series1.XValues.Count = XValues.Length;
would only need to modify one set of arrays and then call ModifySeries for each of his series to propagate the new data through all of his charts. Is this sufficient?
The trick here is that, as it says at http://msdn.microsoft.com/en-us/library/9b9dty7d.aspx, "Array types are reference types derived from the abstract base type Array." As reference types (http://msdn.microsoft.com/en-us/library/490f96s2.aspx), "two variables can reference the same object; therefore, operations on one variable can affect the object referenced by the other variable.". This can be seen with this example:
    double[] Array, CopyArray;
      Array = new double[] { 1, 2 };
      CopyArray = Array;
      Array[1] = 7;
      MessageBox.Show(CopyArray[1].ToString());
