Bug 794 - The Y and X axes labels aren't centred correctly when LabelExponent is true
Summary: The Y and X axes labels aren't centred correctly when LabelExponent is true
Reported: 2014-06-11 05:52 EDT by sandra pazos
Modified: 2014-06-16 05:53 EDT (History)
Exponent example (deleted)
2014-06-11 05:52 EDT, sandra pazos
Exponent example (62.81 KB, application/x-zip-compressed)
2014-06-11 06:45 EDT, sandra pazos
Description sandra pazos 2014-06-11 05:52:58 EDT
Created attachment 225 [details]
Exponent example
On the Y axis, the vertical centering is not correct. If you turn labelsExponent on or off it should move the label up or down, because now you are drawing the exponent in superscript, making it higher. Instead, the label stays in the same position
Note on the X axis is also not centered correctly on the grid line.  It seems to somehow be anchored to the left edge of the exponent, but the entire text of the label should be centered.
Using attached example you can see the problem.
Comment 1 sandra pazos 2014-06-11 06:44:50 EDT
The content of attachment 225 [details] has been deleted
Comment 2 sandra pazos 2014-06-11 06:45:09 EDT
Created attachment 228 [details]
Exponent example
