Bug 793 - The distance between the label and the Y axis is wrong when LabelExponent is true.
Summary: The distance between the label and the Y axis is wrong when LabelExponent is...
: High enhancement
Reported: 2014-06-11 05:44 EDT by sandra pazos
Modified: 2014-06-13 09:40 EDT (History)
Example that reproduces the Y axis distance problem. (deleted)
2014-06-11 05:44 EDT, sandra pazos
Example that reproduces the Y axis distance problem. (62.81 KB, application/x-zip-compressed)
2014-06-11 06:44 EDT, sandra pazos
Description sandra pazos 2014-06-11 05:44:47 EDT
Created attachment 224 [details]
On the Y axis, the distance between the label and the axis is wrong. When you have the exponent, the text is too far from the axis. It appears as if the label is being sized, presuming that the exponent will not be drawn in superscript.
I.E: if you turns labelsExponent off, the label looks like and it is perfectly positioned near the axis.
When you turn labelsExponent on, the position of the label does not move enough to bring the superscripted exponent close to the axis.
The attached project reproduces the problem.
Comment 1 sandra pazos 2014-06-11 06:40:52 EDT
The content of attachment 224 [details] has been deleted
Comment 2 sandra pazos 2014-06-11 06:44:02 EDT
Created attachment 227 [details]
