Bug 777 - Chart Editor doesn't save the design time changes
Summary: Chart Editor doesn't save the design time changes
Version: TeeChart Pro Activex Control v2014 v2014.0.0.0 Release
Reported: 2014-05-22 04:36 EDT by sandra pazos
Modified: 2015-06-23 07:15 EDT (History)
Description sandra pazos 2014-05-22 04:36:40 EDT
Sometimes the Chart Editor doesn't save the changes that you do in design time. For example, in the case you change the chart fonts from Verdana to Arial by design time editor when you run the application the changes are reset to initial. The same occurs when you change the Zoom properties. The problem isn't produced if you modify the properties by code.
Comment 1 marc meumann 2015-06-23 07:15:20 EDT
Problem relating to contention between default Font assigned with Theme and default Font assigned at Chart create time. Some deigntime Font changes were not signalling correctly as 'change from default'. Fixed for next update.
