Bug 770 - Problem with installation of VS2008 components
Summary: Problem with installation of VS2008 components
Reported: 2014-05-15 05:02 EDT by christopher ireland
Modified: 2015-06-17 11:34 EDT (History)
InstallError2 (11.31 KB, image/png)
2014-07-16 21:01 EDT, Shinobu Nagai
InstallQuestion1 (21.36 KB, image/png)
2014-07-16 21:02 EDT, Shinobu Nagai
InstallQuestion2 (7.73 KB, image/png)
2014-07-16 21:05 EDT, Shinobu Nagai
Description christopher ireland 2014-05-15 05:02:34 EDT
Run the installer, select VS2008 and the two available components and run it. An error is thrown as the TeeChart.Silverlight.dll is not found.
Comment 1 Shinobu Nagai 2014-07-16 21:01:30 EDT
Created attachment 246 [details]
InstallError2
Comment 2 Shinobu Nagai 2014-07-16 21:02:05 EDT
Created attachment 247 [details]
InstallQuestion1
Comment 3 Shinobu Nagai 2014-07-16 21:02:33 EDT
Created attachment 248 [details]
InstallQuestion2
Comment 4 Shinobu Nagai 2014-07-16 21:05:54 EDT
Created attachment 249 [details]
InstallError2
Comment 5 Shinobu Nagai 2014-07-17 00:11:27 EDT
I installed TeeChart for VS2008 using TeeChartNET2014EVAL_4.1.2014.05095.exe, by selecting VS2008 and the two available components. I didn't mark either the "Select all assemblies" nor "Uses http proxy" checkboxes.
Besides the error Chris reported, I get the same error with the trial version, and TeeChart.Silverlight.dll was missing in net35/x86 folder.
Besides this error, I got the attached InstallError2.png, as well.
As I mentioned above, I didn't mark the "Select all assemblies", but net40 folder is created. Not all of the dlls are placed in it.
If I'm not wrong, I think I got the similar errors when installing the trial version of VS2013, too. Don't you do the installation tests before publishing them?
Comment 6 Shinobu Nagai 2014-07-22 21:56:34 EDT
Please let me know the status of this issues. Will they be fixed soon?
Comment 7 christopher ireland 2014-07-23 03:20:40 EDT
Nagai,
This issue will be looked at when the next maintenance release is built. The next maintenance release is due out just before 15th of August.
Thank you.
Comment 8 Shinobu Nagai 2014-11-12 23:37:41 EST
I installed the latest trial version of Steema TeeChart for .NET 2014 4.1.2014.08120. If I launch the DemoProjectSilverlight, an error message that says "couldn't find TeeChart.Silverlight.dll" as it's created for runtime.
Recently, we received the one that worked correctly in VS2008,the Product version. So, we are about to release the maintenance versions for the Japanese versions soon.
However, the same error occurs with the dll for the trial version. Could you be so kind to send me the one for the trial version that doesn't cause the error asap?
Comment 9 sandra pazos 2015-06-17 11:34:10 EDT
Hello Nagai,
Could you tell us if you can still reproduce the problem using latest TeechartFor.Net, build 4.1.2015.05145?
Thanks in advance,
regards.
