Bug 77 - Marks inheriting the Series transparency
Summary: Marks inheriting the Series transparency
Version: 131016
Reported: 2013-11-06 10:56 EST by yeray alonso
Modified: 2013-11-13 10:28 EST (History)
Description yeray alonso 2013-11-06 10:56:36 EST
See the example in the forums:
http://www.teechart.net/support/viewtopic.php?p=63460#p63460
With v2013, the Mark Fonts are a bit transparent even if you don't set Marks transparency. The Shape, Font and Pens should have independent transparencies.
Comment 1 david berneda 2013-11-06 11:48:18 EST
Yes, this is a breaking change compared to previous versions.
The reasoning is, if you apply transparency to a series you'll usually want also transparency to everything that belongs to that series (marks, additional drawings in some series, etc).
Main reason is if you apply a fade-out or fade-in animation to a series, you want everything to appear or disappear, not just the series points.
One possible solution for a next update can be a new property at Marks level, to disable using its parent Series transparency:
  Series1.Transparency := 30;
  Series1.Marks.UseSeriesTransparency := False;  // default True
Comment 2 david berneda 2013-11-13 10:28:34 EST
Fixed by adding a new property to Series Marks to not make use of Series transparency:
Default is True.
The same concept could be applied to other elements (Font, Pen, etc) as a generic new property "ParentTransparency:Boolean default True".
