Bug 739 - Setting the chart's BevelOuter to bvNone in GDI makes the panel color to be drawn at the right and bottom
Summary: Setting the chart's BevelOuter to bvNone in GDI makes the panel color to be d...
: High normal
Reported: 2014-04-24 06:41 EDT by yeray alonso
Modified: 2014-11-07 13:36 EST (History)
3 users (show)
Description yeray alonso 2014-04-24 06:41:03 EDT
Setting the chart's BevelOuter to bvNone in GDI makes the panel color to be drawn at the right and bottom.
uses TeCanvas;
var Chart1: TChart;
  Chart1:=TChart.Create(Self);
  Chart1.Parent:=Self;
  Chart1.Align:=alClient;
  Chart1.Canvas:=TTeeCanvas3D.Create;
  Chart1.BevelOuter:=bvNone;
  Self.Color:=clRed;
This appeared with rev 1.40 of TeeProcs.pas.
It works fine again if I change, at TCustomTeePanelExtended.PanelPaint this:
with Canvas do
  Brush.Color:=Self.PanelColor(tmpColor);
for this:
with Canvas do
  Brush.Color:=Self.Color;
But this won't probably be the desirable fix. Maybe we should inflate the rectangle when BevelOuter=bvNone
Comment 1 John Ioannides 2014-11-05 03:16:15 EST
Is it safe to use the fix proposed by Alonso?
Comment 2 david berneda 2014-11-07 13:36:42 EST
A different fix has been done, increasing the rectangle right and bottom coordinates to cover the missing pixels.
Still, there is one case where its not working, when:
  Chart1.BorderRound:=20;
Another case that works fine is:
  Chart1.Border.JoinStyle:=jsMitter;
  Chart1.Border.Show;
  Chart1.Border.Width:=3;
The fix is at TeeProcs.pas unit, at sub-procedure "PaintBack" inside the TCustomTeePanelExtended.FillPanelRect method:
  procedure PaintBack(ARect:TRect; AColor:TColor);
    // PrintTeePanel is a "trick" to paint Chart background also when printing.
    // When AColor = clNone, it means background should NOT be painted at all.
    with Canvas do
      if AColor=clNone then
         Brush.Style:=bsClear
        Brush.Color:=AColor;
        Brush.Style:=bsSolid;
        Brush.Image:=nil;
      if Border.Visible then
         FixBorderWidth(ARect)
        ARect.Right:=ARect.Right+1;
        ARect.Bottom:=ARect.Bottom+1;
      if BorderRound>0 then
         Canvas.RoundRect(ARect,BorderRound,BorderRound)
         Canvas.Rectangle(ARect);
