Bug 734 - Exporting to image the size of the first exported chart is used, not the actual
Summary: Exporting to image the size of the first exported chart is used, not the actual
Reported: 2014-04-16 10:18 EDT by yeray alonso
Modified: 2017-01-09 12:03 EST (History)
Description yeray alonso 2014-04-16 10:18:03 EDT
Here a simple example:
Private Sub Command1_Click()
  TChart1.Export.asJPEG.SaveToFile "e:\\tmp\\testAXSize1.jpg"
Private Sub Command2_Click()
  TChart1.Width = TChart1.Width + 1000
  TChart1.Export.asJPEG.SaveToFile "e:\\tmp\\testAXSize2.jpg"
Private Sub Form_Load()
  TChart1.Aspect.View3D = False
- Click on Button1
- Click on Button2
- Compare the images generated. Both testAXSize1.jpg and testAXSize2.jpg have the same size. This is wrong.
- Then close and restart the application
- Click on Button2
- Now testAXSize2.jpg has the updated and correct size.
This doesn't happen in VCL with the following code:
uses TeeStore, TeeJpeg;
var exportFormat: TJPEGExportFormat;
  exportFormat:=TJPEGExportFormat.Create;
  exportFormat.Panel:=Chart1;
  exportFormat.SaveToFile('e:\tmp\testVCLSize1.jpg');
  Chart1.Width:=Chart1.Width + 100;
  exportFormat.SaveToFile('e:\tmp\testVCLSize2.jpg');
