Bug 71 - BackImage & pbmStretch causes wrong rendering
Summary: BackImage & pbmStretch causes wrong rendering
Version: 131016
URL: http://www.codeproject.com/Articles/1...
Reported: 2013-11-05 09:43 EST by narcís calvet
Modified: 2013-11-05 12:38 EST (History)
test project (2.66 KB, application/octet-stream)
2013-11-05 09:43 EST, narcís calvet
Modified test project showing differences between GDI and GDI+ (8.11 KB, application/x-zip-compressed)
2013-11-05 10:58 EST, david berneda
Description narcís calvet 2013-11-05 09:43:47 EST
Created attachment 12 [details]
test project
If you add a BackImage and set BackImageMode to pbmStretch, there are painting issues along the left and right borders of the chart. The painting artifacts are not visible when the BackImageMode is set to pbmTile. The problem gets worse when rendering is changed from GDI+ to GDI. Note that the issue is visible during design-time and run-time. Find attached project reproducing this.
Comment 1 david berneda 2013-11-05 10:54:25 EST
GDI+ :
This is due to the named "BorderBug" of GDI+:
http://www.codeproject.com/Articles/14884/BorderBug
One solution for "flat" (no detail) images that are enlarged, is to use "low" stretch quality.
Chart1.Canvas.StretchDrawQuality:=sqLow;
but, this property is at canvas level, and not at Chart BackImage level.
I'll implement this as an option at BackImage level so it'll be available for any chart element shape back picture, ie:
Chart1.BackImage.DrawQuality := sqLow;
GDI :
With GDI, TeeChart does its own stretch algorithm instead of using GDI StretchBlt, to obtain a better smooth quality.
This works fine when both reducing or enlarging an image, but emits noise when on content areas that are "flat" (no detail, such as single color backgrounds).
The above DrawQuality property will also be handy with GDI, to use the default GDI stretch instead of the internal one.
Comment 2 david berneda 2013-11-05 10:58:40 EST
Created attachment 14 [details]
Comment 3 david berneda 2013-11-05 12:38:44 EST
Fixed with TBackImage.DrawQuality new property.
Default is "sqHigh".
