Bug 692 - SurfaceNearestTool method GetRowCol, never return the first column of Surface
Summary: SurfaceNearestTool method GetRowCol, never return the first column of Surface
Version: 140220
Reported: 2014-04-01 07:09 EDT by sandra pazos
Modified: 2014-04-09 10:19 EDT (History)
Nearest Surface Tool Problem (57.03 KB, application/x-zip-compressed)
2014-04-01 07:09 EDT, sandra pazos
Description sandra pazos 2014-04-01 07:09:37 EDT
Created attachment 145 [details]
The SurfaceNearestTool method GetRowCol returns all Surface rows and columns selected, except the first column. Attached project show the problem. This behaviour isn't produced in TeeChart.Net.
Comment 1 david berneda 2014-04-09 10:16:25 EDT
The first column you mean it returns columns always from 2 to 30 in this example?
I guess the problem is its returning rows from 1 to 29, but columns from 2 to 30.
There is an internal code that controls if the surface is "back faced", ie: if you rotate the surface 180 degrees, the tool should work and return the same values as if not rotated.
The solution might be always returning the Col number -1 in all cases.
Comment 2 david berneda 2014-04-09 10:19:32 EDT
Fixed. Now the column returned in GetRowCol function is always decremented by 1.
Warning: This change can break existing code assuming the column is always +1.
