Bug 686 - When adding axes on the right side, there is not enough space preserved for the axis name
Summary: When adding axes on the right side, there is not enough space preserved for t...
Reported: 2014-03-31 04:15 EDT by Alexander Cosman
Modified: 2014-04-15 07:58 EDT (History)
Chart with right axes partially visible (127.03 KB, image/png)
2014-03-31 04:15 EDT, Alexander Cosman
Description Alexander Cosman 2014-03-31 04:15:52 EDT
Created attachment 143 [details]
The custom axes on the right side of the chart are not displayed correctly, because there is not enough space for the axis name.
Example:
I create a canvas with width=1656 and height=739.
I create a chart and add some custom axes and then I draw the chart (see attachment)
You can see that there is not enough space for the axes names (on the right side)
When I mannually set the bounds of the charts to chart.bounds.width=1600 and chart.bounds.height=700 before executing chart.draw(), then I see that everything is drawn (so the axis name is visible).
Comment 1 sandra pazos 2014-04-01 10:13:55 EDT
The code below reproduce the problem:
function draw() {
  // Create a Chart1 using canvas1:
  // Add four line series, with 200 random points each:
  Chart1.addSeries(new Tee.Line()).addRandom(200);
  // Create additional axes:
  var axis1=Chart1.axes.left;
  var axis2=Chart1.axes.add(false,false);
  var axis3= Chart1.axes.add(false,true);
  var axis4=Chart1.axes.add(false,true);
  // Setup axis positions as % percent:
  axis1.start= 0; axis1.end=50;
  axis2.start=50; axis2.end=100;
  axis3.start=0; axis3.end=50;
  axis4.start=50; axis4.end=100;
  //Add Title
  axis1.title.text="Axis 1";
  axis2.title.text="Axis 2";
  axis3.title.text="Axis 3";
  axis4.title.text="Axis 4";
  axis1.title.rotation = 90;
  axis2.title.rotation=90;
  axis3.title.rotation = 90;
  axis4.title.rotation = 90;
   // Set series with axes:
  Chart1.series.items[0].vertAxis=axis1;
  Chart1.series.items[1].vertAxis=axis2;
  Chart1.series.items[2].vertAxis=axis3;
  Chart1.series.items[3].vertAxis=axis4;
  Chart1.legend.visible= false;
  // Draw
  Chart1.draw();
Comment 2 marc meumann 2014-04-15 07:37:07 EDT
Recommend use of standard chart axes before adding custom axes. Axis calculations will then size correctly.
eg.
    var Chart1;
    function draw() {
        Chart1 = new Tee.Chart("canvas");
        var axis1 = Chart1.axes.left;
        var axis2 = Chart1.axes.add(false, false);
        //var axis3 = Chart1.axes.add(false, true);
        var axis4 = Chart1.axes.add(false, true);
        var axis5 = Chart1.axes.right;
        axis1.start = 0; axis1.end = 50;
        axis2.start = 50; axis2.end = 100;
        //axis3.start = 0; axis3.end = 50;
        axis5.start = 0; axis5.end = 50;
        axis4.start = 50; axis4.end = 100;
        //Add Title
        axis1.title.text = "Axis 1";
        axis2.title.text = "Axis 2";
        //axis3.title.text = "Axis 3";
        axis5.title.text = "Axis 5";
        axis4.title.text = "Axis 4";
        axis2.title.rotation = 90;
        //axis3.title.rotation = 90;
        axis5.title.rotation = 90;
        Chart1.series.items[0].vertAxis = axis1;
        Chart1.series.items[1].vertAxis = axis2;
        //Chart1.series.items[2].vertAxis = axis3;
        Chart1.series.items[2].vertAxis = axis5;
        Chart1.series.items[3].vertAxis = axis4;
        Chart1.legend.visible = false;
        // Draw
        Chart1.draw();
Comment 3 marc meumann 2014-04-15 07:58:11 EDT
TeeChart internal code change. Fixed for inclusion in next update.
