Bug 672 - Null values within the values should be ignored when calculating the ranges
Summary: Null values within the values should be ignored when calculating the ranges
Reported: 2014-03-27 12:19 EDT by Alexander Cosman
Modified: 2014-03-28 11:43 EDT (History)
The bad chart with wrong minimum and maximum (20.23 KB, image/png)
2014-03-27 12:20 EDT, Alexander Cosman
The good chart with correct minimum and maximum (105.88 KB, image/png)
2014-03-27 12:22 EDT, Alexander Cosman
Description Alexander Cosman 2014-03-27 12:19:40 EDT
When we add null values in the values array of a serie. The minimum and maximum of the axes are calculated wrong. The inserted null value should be ignored, instead of assuming it was 0.
e.g we create a chart that shows a frequency +-50hz. The minimum and maximum are around 49 and 51, when there is no null value within the values. When the null value is added, the minimum is changed to 0.
Comment 1 Alexander Cosman 2014-03-27 12:20:30 EDT
Created attachment 135 [details]
Comment 2 Alexander Cosman 2014-03-27 12:22:06 EDT
Created attachment 136 [details]
For this chart we don't have any null values within the values
Comment 3 marc meumann 2014-03-28 07:27:47 EDT
reproducible.
These codelines may be used for tests:
function draw() {
  Chart1=new Tee.Chart("canvas");
  Chart1.addSeries(new Tee.Line([20,19,18,17,16,15,14,13,12,11,10,11,12,13,14,null,16,17,18,19,20,21,22,23,24,25,26,27,28,29]) );
  Chart1.draw();
Comment 4 marc meumann 2014-03-28 11:25:50 EDT
"The Math.min function performs (the internal function) ToNumber() on each array element, which in turn coerces the values to Number."
ref.
http://stackoverflow.com/questions/11817861/math-min-apply-returns-0-for-null
Fix applied to ArrayMin/ArrayMax, teechart.js
Comment 5 Alexander Cosman 2014-03-28 11:43:05 EDT
Where can I download the new version?
