Bug 668 - Surface series palettestyle doesn't serialize all possible styles.
Summary: Surface series palettestyle doesn't serialize all possible styles.
Reported: 2014-03-27 04:41 EDT by sdgr
Modified: 2014-03-28 10:08 EDT (History)
Chart Series: Surface 3D
Description sdgr 2014-03-27 04:41:29 EDT
I have a Surface series and set the PaletteStyle property to 'Strong'.
Saving the chart and reloading it, the PaletteStyle is set to the first style in the list, which is 'Pale' (this is wrong), but my surface series doesn't show like it is 'Pale' (it shows my surface in 2 colors, instead of using the palette).
Saving a Surface series with PaletteStyle property = 'Pale', does the same as explained above.
Saving a Surface series with PaletteStyle='Grayscale' or 'InvertedGray' or 'Rainbow' and reloading it afterwards, does display correctly!
This doesn't happen only to a Surface series, it happens also for ColorGrid series, ...
Is there a workaround?
Stefan.
Comment 1 christopher ireland 2014-03-27 05:43:29 EDT
This bug is now fixed. In the meantime, as a workaround, you can derive your own surface class to mitigate the problem.
    MySurface series;
      series = new MySurface(tChart1.Chart);
      series.FillSampleValues();
      series.UseColorRange = false;
      series.UsePalette = true;
      series.PaletteStyle = PaletteStyles.Strong;
      MemoryStream ms = new MemoryStream();
      tChart1.Export.Template.Save(ms);
      ms.Position = 0;
      tChart2.Import.Template.Load(ms);
      MessageBox.Show(((Surface)tChart2[0]).PaletteStyle.ToString());
  public class MySurface : Surface
    public MySurface(Chart c) : base(c)
Comment 2 sdgr 2014-03-27 06:50:57 EDT
Thanks for the update.
I assume that the solution will be added to the next available release?
Any idea when the next is sheduled?
Stefan.
Comment 3 christopher ireland 2014-03-28 10:08:19 EDT
The last release was on the 24th of February - I would expect the next release to be made public on or around the 24th of April.
