Bug 664 - ColorLine doesn't show when the Axis is Inverted
Summary: ColorLine doesn't show when the Axis is Inverted
Version: 140220
Reported: 2014-03-25 06:33 EDT by yeray alonso
Modified: 2014-03-27 13:52 EDT (History)
ColorLine invisible when Inverted Axis (1.84 KB, application/octet-stream)
2014-03-25 06:33 EDT, yeray alonso
Description yeray alonso 2014-03-25 06:33:48 EDT
Created attachment 130 [details]
See the project attached.
If you don't invert any axis, you can drag the colorline, zoom & scroll without problems.
If you invert an axis, the colorline linked to it is still present but not drawn.
If you move the mouse around the chart you find the colorline because the cursor changes to drag mode, but you can't see the tool. And if you scroll, zoom or drag the invisible tool, then it seems to snap to the edges of the chartrect. Curious.
Comment 1 david berneda 2014-03-27 13:52:21 EDT
This method was wrongly inverting start and ending coordinates when the axis is inverted:  TColorLineTool.GetAxisStartEnd
Correct code:
procedure TColorLineTool.GetAxisStartEnd(out AStart,AEnd:Integer);
  AStart:=Axis.IStartPos;
  AEnd:=Axis.IEndPos;
