Bug 662 - Crash when area is zero
Summary: Crash when area is zero
Product: FireMonkey TeeChart
Hardware: Tablet Android
: --- minor
Reported: 2014-03-24 08:55 EDT by Daniel Marschall
Modified: 2018-02-23 12:25 EST (History)
Description Daniel Marschall 2014-03-24 08:55:38 EDT
We accidently created a 2-axis chart with following values:
yMin=0,
yMax=0,
xMin=0,
xMax=0,
when we launched the application, it just did close. No Exception was thrown. I think it might be an internal DivByZero-Exception which was not catched by Delphi?
Solution: An Exception should always be thrown. Not just closing the app.
Comment 1 david berneda 2014-03-24 12:29:58 EDT
Cannot reproduce.
I made a FireMonkey Delphi project using XE5, with the code below, and executed fine in Android device:
procedure TForm213.FormCreate(Sender: TObject);
  Chart1.Axes.Left.SetMinMax(0,0);
  Chart1.Axes.Bottom.SetMinMax(0,0);
Are you doing something different?
Comment 2 Daniel Marschall 2014-03-24 13:40:55 EDT
(Bezüglich comment 1 von david berneda)
I did use:
LeftAxis.Min := 0;
LeftAxis.Max := 0;
BottomAxis.Min := 0;
BottomAxis.Max := 0;
I can test it with a new project tomorrow to isolate the behavior.
Comment 3 Daniel Marschall 2014-03-24 13:43:38 EDT
Correction: The Code is actually:
  Chart1.BottomAxis.Minimum := InterpretedMetadata.xMin;
  Chart1.BottomAxis.Maximum := InterpretedMetadata.xMax;
  Chart1.LeftAxis.Minimum   := InterpretedMetadata.yMin;
  Chart1.LeftAxis.Maximum   := InterpretedMetadata.yMax;
Where InterpretedMetadata is an accidently empty record with all double's set to 0.
Comment 4 Daniel Marschall 2014-03-25 07:33:49 EDT
I could successfully reproduce the bug with all my mobile devices.
Btw, do you know why the app just closes? I have experienced many cases of AccessViolations where the app just closed instead of showing at least an error message. Is this a bug in Delphi's RTL? (I use XE5 SP2)
http://download.rinntech.com/marschall/Bug662-Reproduction.zip
Comment 5 Daniel Marschall 2014-03-25 08:27:56 EDT
I just installed the Update http://cc.embarcadero.com/item/29708 . The app doesn't close now and brings the message "Axis Minimum Value must be <= Maximum".
(The problem was actually the uninitialized record, which did have random values instead of zeros)
You can mark the bug as already fixed.
But could you still explain, why the app closes in some kinds of Exceptions, please? Should Embarcadero be informed about this?
Comment 6 david berneda 2014-03-27 14:07:44 EDT
XE5 Update2 fixed one similar case (access violation closing Android app):
http://qc.embarcadero.com/wc/qcmain.aspx?d=117507
There might be other related issues. XE5 Update 2 has several fixes similar:
http://edn.embarcadero.com/article/43522
I'll investigate and try to determine the cause, TeeChart Axis has some protection against floating point overflows, maybe these aren't working fine in Android.
