Bug 639 - empty marks display non-empty marks text.
Summary: empty marks display non-empty marks text.
Version: 140220
Reported: 2014-03-14 12:14 EDT by narcís calvet
Modified: 2014-03-17 09:34 EDT (History)
Only one mark (index 3) should be displayed. (5.94 KB, application/x-zip-compressed)
2014-03-14 12:14 EDT, narcís calvet
Description narcís calvet 2014-03-14 12:14:17 EDT
Created attachment 117 [details]
The attached project should only display display a mark, where index is 3, other marks should not be displayed. However, it copies the same mark for all points in the series.
A workaround is implementing OnGetMarkText event like this:
procedure TForm1.Series1GetMarkText(Sender: TChartSeries;
  ValueIndex: Integer; var MarkText: String);
  if Series1.Labels[ValueIndex]='' then
    MarkText:='';
Comment 1 david berneda 2014-03-17 07:41:45 EDT
This behaviour has always been like this.
The default "smsLabel" style will use the point Label, and if empty, it will use the point Value.
We will need to add a new style enum to not break backwards compatibility:
  Series1.Marks.Style :=  smsLabelOnly ;
Comment 2 david berneda 2014-03-17 09:34:56 EDT
Fixed. The best solution is:
1) A new enum has been added, and this new enum is made the default:
Series1.Marks.Style := smsLabelOrValue
2) The existing smsLabel will now return only the series point text Label.
If label is empty (''), no mark will be displayed.
Compatibility:
Existing charts with old default smsLabel will use the new smsLabelOrValue when loaded.  Everything will work as before.
The only backwards-compatible problem is when Style is set by code to "smsLabel".  In this case, empty Labels will not display Value.
If this is the desired behaviour, style should be set to smsLabelOrValue.
