Bug 626 - Changing ScrollPager.ColorBandTool StartValue and EndValue doesn't affect the main chart
Summary: Changing ScrollPager.ColorBandTool StartValue and EndValue doesn't affect the...
Version: 140220
: Lowest enhancement
Reported: 2014-03-11 09:04 EDT by yeray alonso
Modified: 2014-03-12 06:56 EDT (History)
Description yeray alonso 2014-03-11 09:04:26 EDT
Changing ScrollPager.ColorBandTool StartValue and EndValue doesn't affect the main chart.
It could be interesting to add some method to both set the ColorBandTool values and the Parent Chart Axis Range with onw unique call.
At the moment, if you do this:
  ScrollPager.ColorBandTool.StartValue:=500;
  ScrollPager.ColorBandTool.EndValue:=600;
The main chart doesn't set its bottom axis min and max; you still have to do it manually:
  Chart1.Axes.Bottom.SetMinMax(500, 600);
http://www.teechart.net/support/viewtopic.php?p=64302#p64302
http://www.teechart.net/support/viewtopic.php?p=65122#p65122
Comment 1 david berneda 2014-03-12 06:56:40 EDT
Implemented.
ColorBand tool has now a new event "OnChanged" that is called whenever the color band Start or End values are modified.
This event is now used internally by ScrollPager tool to refresh the parent chart.
