Bug 611 - Surface series memory leak
Summary: Surface series memory leak
Version: 140220
Reported: 2014-02-28 06:27 EST by narcís calvet
Modified: 2014-02-28 07:05 EST (History)
Chart Series: Surface 3D
C++ Builder test project (48.37 KB, application/x-zip-compressed)
2014-02-28 06:27 EST, narcís calvet
Description narcís calvet 2014-02-28 06:27:40 EST
Created attachment 105 [details]
I found a memory leak in the Surface series, compile test1 program attached and after start check memory at the TaskManager.
I've just checked with the GDI rendering, the bug also exists with the same memory leaking rate. By the way, this bug exists only in the latest TeeChart version (2014.10), previous version works fine: For this reason I am now using the TeeChart November 2013 version.
Comment 1 david berneda 2014-02-28 06:51:39 EST
ReportMemoryLeaksOnShutdown=true is not reporting any leak when the program is finished, so it must be some allocation that is done at repaint time.
Comment 2 david berneda 2014-02-28 07:05:05 EST
Loop accessing GridIndex should start at 1.
When using 0, values aren't found so Value[0,z] and Value[x,0] will add new points to the Series (and so the apparent leak).
Correct code is:
void __fastcall TForm4::Timer1Timer(TObject *Sender)
  for(int x = 1; x <= 128; ++x)
  for(int z = 1; z <= 128; ++z)
    Series1->Value[x][z] = random(512);
