Bug 609 - Streaming of classes derived from TChart affected
Summary: Streaming of classes derived from TChart affected
Version: 140220
Reported: 2014-02-27 09:02 EST by trubetskov
Modified: 2014-02-28 06:09 EST (History)
Project demonstrating this problem. The chart should NOT change after pressing the button (84.19 KB, application/zip)
2014-02-27 09:02 EST, trubetskov
Description trubetskov 2014-02-27 09:02:38 EST
Created attachment 104 [details]
This example demonstrates a new subtle problem with streaming of
classes derived from TChart. Compare how it works with the current release
Feb 2014 and with the previous release Nov 2013.
In the derived class View3D has default setting = False.
Unfortunately LoadChartFromStream recreates a class of TCustomChart type and
uses its default settings, therefore any new defaults in the derived class get lost.
It happens due to the replacement of the following lines in the procedure TeeStore.LoadChartFromStreamCheck:
  { remove all child Series and Tools }
  AChart.FreeAllSeries;
  AChart.Tools.Clear;
with
  AChart.ClearChart;
in the Feb 2014 version.
This problem affects all other attempts to override properties of TChart in the derived classes! In order to fix this issue I reimplemented LoadChartFromStream without calling "ClearChart" inside.
Comment 1 david berneda 2014-02-28 06:09:04 EST
Fixed. ClearChart now uses the current ClassType to call the Create constructor properly.
Procedure TCustomChart.ClearChart;
  procedure InitChart;
  type
    TCustomChartClass=class of TCustomChart;
  var tmpChart : TCustomChart;
      tmpClass : TCustomChartClass;
    // Use ClassType to call derived classes Create constructor
    tmpClass:=TCustomChartClass(ClassType);
    tmpChart:=tmpClass.Create(nil);
    try
      tmpChart.Parent:=Parent;
      Assign(tmpChart);
    finally
      tmpChart.Free;
var t : Integer;
  for t:=0 to SeriesCount-1 do
    if Assigned(Series[t].Datasource) then
      {$IFDEF TEEOCX}
      {$IFDEF DATABASE}
      if (Series[t].DataSource is TTeeADOQuery) then
         Series[t].Datasource.Free
      {$ENDIF}
      {$ENDIF}
        Series[t].Datasource:=nil;
  FreeAllSeries;
  SeriesList.Clear; //TV52015747
  Tools.Clear;
  Animations.Clear;
  for t:=0 to Axes.Count-1 do
      Axes[t].Items.Clear;
  Axes.Reset;
  InitChart;
