Bug 574 - Access Violation rotating 3D plot
Summary: Access Violation rotating 3D plot
: --- critical
Reported: 2014-02-13 06:56 EST by mjs
Modified: 2014-02-28 04:04 EST (History)
SurfaceRotationProblem (62.46 KB, application/x-zip-compressed)
2014-02-19 07:46 EST, sandra pazos
Description mjs 2014-02-13 06:56:23 EST
Code Version: 2013.09 (131217). Bug also appears in latest release version.
When rotating 3D plot (and grid gets outside control bounds?) an access violation occurs (possibly only when max on z-axis < 1?). It can be fixed by the following 2 beginning lines in TCustom3DGridSeries.ExistFourGridIndex in VCLTee.TeeSurfa:
Function TCustom3DGridSeries.ExistFourGridIndex(X,Z:Integer):Boolean;
  Result := False;
  if (x < 0) or (z < 0) then Exit;
The access violation occurs because x = z = -1
Comment 1 sandra pazos 2014-02-13 10:59:25 EST
Unfortunately we can't reproduce your problem here using latest Beta version we published in January
Could you confirm us if your problem occurs using latest beta we published http://www.teechart.net/support/viewtopic.php?f=19&t=14567? In the case your problem persists, please attach here a simple example, where we can reproduce your problem, because we can find a good solution for your problem.
Thanks in advance,
Comment 2 sandra pazos 2014-02-19 07:46:41 EST
Created attachment 93 [details]
Many thanks for your project; We now can reproduce the problem. I have attached your project here, so we can investigate what causes produce it.
